The foot pedal got stuck and wouldn't stop sewing
SOURCE: Needle won't move on Bernina 930
If the machines motor is running but the needle isn't going up and down then the baste stitch finger is gummed up and needs to be serviced. This is a simple fix and it happens all the time on those machines. Take it to your local Bernina dealer for a standard service. Also if you really need it in a pinch try pushing up on the needle bar that sometimes will fix the problem but it will still need serviced.
SOURCE: Bernina Activa 135 sewing machine
Hi , the pedal micro switch are stuck , you may visit fixya repair service just , (enter zip area), you can find sewing machine repairman near you
SOURCE: Husqvarna 2000 sewing machine foot pedal stuck on but not pressed
you may need to take foot pedal apart and clean it the contacts inside may be dirty and causing it to stick
SOURCE: I was sewing and the foot pedal stopped working.
Take your machine in to a Bernina dealer for service. It could be you need a new foot pedal, or if could be something else.
