Good Afternoon Friend,
I see you want to know how to repair your Frigidaire microwave, model# PLMV169DCD. Repairs on microwaves are typically not a do it yourself repair. I suggest contacting your local authorized technician for further assistance. They have been trained specifically on your appliance and will know exactly how to repair your microwave. Hope this is helpful.
-Best Regards-
WP
SOURCE: My Frigidaire over the stove microwave not heating food
Hi,It is most likely the magnetron and diode that has to be replaced. This job should be done by a tech, High voltage. Magnetron's normally have a five year warranty, check your owners manual.
SOURCE: My microwave oven is not heating the food
HI, you will need to replace the heating device. This device is called the Magnetron and, it will cost you about $133.00. This is a repairable issue but, you will need to call for service. I do not recommend installing this device if you are not familiar with handling this type of tech.
Replacing the Magnetron will fix this heating issue you are having with this microwave. The Magnetron is the device that is responsible for the heating action.
SOURCE: My samsung microwave oven is
if your microwave does everything you have described , and you can hear the cooling fan running as well after you press the start button , you probably have a faulty wave guide. The wave guide is also called a Magnetron Tube. It is the main part of the microwave which produces the microwave energy . If this part is not functioning it is best to replace the entire unit, rather than have it repaired .
