It shows that you have physical connection to the DSLAM at your service provider but may not authenticating with the server.
set up the ADSL basic setting with the model name http://support.dlink.com/index.aspx or If you still cannot browse the Internet or not able to access the page. Follow D-link Router Support for share more details.
SOURCE: Can't Access Web configuraton for Cnet CWR-854 Wifi router
Have you try to update the firmware by any chance?
Let me know
comier957
SOURCE: problems setting up 2 wire router
well, go to homeportal/management, type the system password, and on that page you will see the management and diagnostic console of your 2wire modem. there you can make the changes for the wireless channels of the modem. under local network, click on wireless, maximize wireless channels to 11 and set the power settings to 10, then make sure SSID is enabled, WEP is set to default encryption & WEP-open, then click on the submit button on the upper or lower right corner of the screen. then click on statistics, make sure wireless is able to transmit / receive wireless packets. then try to connect to your 2wire network, the SSID is actually 2wirexxx (xxx stands for the last 3 nos. of the serial no.) if it asks for the security key or passphrase for the security enabled network, type the nos. enclosed in brackets found at the barcode sticker just below the serial no. (SN). check if you are able to connect with full access, of course the 2wire modem must be connected using ethernet cable to access the MDC.
for additional info, go to 2wire.com
SOURCE: How to set a static IP address in Windows behind a Linksys Router
Sorry mate but you have kinda lost me here, if you need a static IP address for the internet you need to contact you isp and they will provide you one, if you want to set your machine to set IP Address just go into properties for local network connection and use somthing like 192.168.1.1 255.255.255.0 and leave the dns to obtain. but you wont be able to set a internet static ip address by doing this, only way is to contact your isp.. All the best John
SOURCE: Router cannot connect on internet at setup wizard
Hi pag Smartbro ang gamit mo hindi mo pwede gamiting ang setup wizard. Iba kasi ang paraan ng connection sa SMartBro. Mahirap explain it would be best if you call Linksys Philippine support since there are so many ways to connect Smartbro to a Linksys router. The number is 1-800-1-114-1695 toll free. or kung gusto mo sa Yahoo ID ko nalang mastersaintx message mo ko sa umaga.
