The water jets in most spas are adjustable so you can turn the water flow down to just a trickle if you want to.
You don't take current spa jets out of the spa. They are held in place by a couple of tabs. Through the years the chlorine/bromine will deteriorate those tabs and the spa jets will start "popping" out when the jets get turned on.
If you pull the jet insert out the socket they are in, you will ruin the jet insert and it will need to be replaced.
Water jets will not work?? Is your pump on? I would expect to open ports on the top to introduce air to the water stream. Is this the case with your unit?
