Question about Casio FX-115ES Scientific Calculator
Decimal answer fx-300ES
My answer, when dividing, keeps coming up with a fraction. For example, I put in 43/200 and it gives me 43 over 200, which is of no use what so ever. Thanks!
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
Press SHIFT MODE 2 to switch to the LineIO mode.
Posted on May 13, 2014
6ya staff
SOURCE:
cje240
SOURCE: How do I get decimal answers
I had the same problem. To change the output to decimals, do the following:
Go to Math mode, then SHIFT, MODE (set-up), 2 (lineIO). This will cause answers to show in decimal format. I hope this helps.
I was able to find a manual at: http://www.generalmanual.com/Calculators/Casio-FX-300ES-Scientific-Financial-Calculator.htm
Posted on Jan 25, 2008
Anonymous
SOURCE: When I divide answers are always given in Fractions. Can I change it to come out in decimals?
To change from Fraction display to Decimal display on the Casio fx-300ES (and probably other calculators)
1) Press the "SHIFT" button
2) Press the "MODE/SETUP" button
3) Press the "2" button
This Changes it to LINEIO (Decimal)
Doing all of the above but pressing the "1" button instead of the "2" puts it back into MATHIO mode (Fraction)
Hope this Helps
(SHIFT)(MODE/SETUP)(2) to change to decimal
Posted on Dec 08, 2008
Anonymous
  • 41 Answers
SOURCE: how to divide numbers in to decimals with out it
'shift' 'mode' 'v' (down-arrow) '4' (select 'Disp') '1' (select 'Dot')
Posted on Sep 15, 2009
k24674
  • 8081 Answers
SOURCE: Casio fx-300ES Default answer readout?
Generally, MathIO gives results in fractions or radicals. But sometimes it does not. I tried multiplying or dividing fractions or radicals by integer numbers, and once in while I got a decimal result and was unable to cast it into a fraction or a radical. I was not able to find the pattern.
In lineIO you only get decimal results.
What can one tell you that you cannot determine for yourself? If you appreciate the functionalities of the MathIO, it seems like an insignificant price to pay to press ONE button to switch between displays. It needs to be done ONLY once, for the last result one wants to record.
Your calculator, Your rules. But sometimes one cannot eat the cake and have it too.
Posted on Oct 21, 2009
  • 102366 Answers
SOURCE: i have a fx-300ES casio
Press SHIFT MODE 2 to select LineIO mode. Now all results will come out in decimal form.
Posted on Aug 31, 2010
When i try and divide it just gives me the answer back as a fraction
To convert a single result to decimal, press SD. To have all results come out in decimal, press SHIFT MODE 2 to select the LineIO mode.
Oct 09, 2010 | Casio fx-300ES Calculator
Whenever i try to divide, the calculator gives me a fraction as an answer
To convert a single result to decimal, press SD. To have all results come out in decimal, press SHIFT MODE 2 to select LineIO mode.
Sep 17, 2010 | Casio fx-300ES Calculator
My fx-300ES calculator keeps giving me a fraction wheniever i try to divide. help me please!
To convert a single result to decimal, press S--D. To have all results come out in decimal, press SHIFT MODE 2 to switch to the LineIO mode.
How do i get a decimal on division instead of a fraction? in example when divide 100 by 3 it gives 100/3 instead 33.3
  1. If a fraction (or a radical) is already displayed press the [S<=>D] key to convert it into a decimal number.
  2. If you are entering an expression and want its result displayed as a decimal number, press the [SHIFT][=] key sequence instead of just [=].
  3. More permanent solution: If you do not want fractions nor radicals, configure the Input/Output to be LineIO. To do that, press [SHIFT][MODE] to access the (SETUP) then select the option [2:LineIO]
Jun 01, 2010 | Casio fx-300ES Calculator
Oct 20, 2009 | Casio fx-300ES Calculator
Say for instant i wanted to do a promblem 75 divided by 100 = 3/4 i want change answer that is a fraction to a decimal i can the answer clear
75/100 [=] gives 3/4. Press [S<->D] key to convert to decimal 0.75
0.75 [=] gives 0.75 Press [S<->D] key to convert to fraction 3/4
It can convert radicals into decimal and decimals into radicals.
Hope it helps.
Sep 28, 2009 | Casio fx-300ES Calculator
Hope this Helps
Nov 07, 2008 | Casio fx-300ES Calculator
Casio FX-115ES Scientific Calculator Logo
88 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Ekse
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
