Canon PowerShot A560 Digital Camera Logo
A
Anonymous Posted on May 12, 2014
How to reset camera lens error - Canon PowerShot A560 Digital Camera
Paul S
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Jun 19, 2014
Paul S
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
685
Points
7
The lens error message is often the "kiss of death" for these cameras. If the camera was dropped or bumbed hard while the lens was extended it has internal damage that not likely can be fixed. However, sometimes sand and dirt are the problem and I got lucky fixing one with an air compressor. First install fully charged batteries. Push the little button in front of the camera, it is low and next to the lens, and remove the aluminum ring that goes around the lens. Start smacking the camera on a semi hard surface like a phone book, hitting it on the camera corners and edges, but careful not to hit the corner of the camera hard where the battery door is, battery door breaks easily. Have access to an air compressor, canned air is not powerful enuf. You will need a small air tip, like a trigger operated air blower with small diameter tip. Blow compressed air thru and around all the thin little slots around the lens, alternating smacking the camera while attemting to turn it on. If sand particles are locking the lens, hopefully this will clear it. Good Luck.
How do you reset "lens error"
Go to this website for solutions:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
1helpful
Lens error, restart camera
Sir,
The problem seems that miniscule dust/sand particles jam the gears which moves the lens.
It is possible to turn the lens motor by hand bit by bit and remove particles stuck in the gear.
Also try restoring the factory settings and resetting the camera and seeing if that makes the error to go away. To do that, hold down the Menu button for five seconds. This should reset everything and (hopefully) make the error stop. If it doesn't, then you've got a separate problem-- come back and let us know if the error is still there. Also, if you have photos stored on the camera's internal memory, resetting the camera will delete those so make sure to download them first.
Thanks
Canon PowerShot A420 reset lens error message
Not a solution, but a smilar problem with Canon Power shot A2000IS. Same lens error. reset camera message. Lens alos in fully open position.
Also in Costa Rica.
Any suggestions?
Neil
1helpful
LENS ERROR
On the camera menu, navigate to the RESET command and select it. THe camera should reset and work properly.
Lens Error. Restart Camera. Camera gives this error message and then shuts off. I can't access photos or function buttons. What can I do?
Press the "MENU" button and navigate to the reset command and reset the camera. That may get the camera to function properly.
Canon ixus 75 digital camera reset?
Hi
What you are seeing is just an error message, starting your camera again won't do anything unfortunately.
You need to replace the lens, we have your lens repair available on our site for about $75! If we can help please let us know.
Thomas
Owner- Darntoothysam com
2answers
Lens error on Cannon Powershot SD600
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
When i tun it on it says lens error!??
Seems your camera gone mad and needs Electronic Doctor immediately. :D
2answers
Hp 735 camera error e106 then it turns off
When the camera is turned on, the lens is stuck either in or out and the camera gives the error E104 , E105 , or E106 . The camera then turns itself off. Causes These errors display because the lens will not move. There are several reasons why the camera lens might not move:
  • something is blocking the lens
  • the firmware version is old
  • the camera has been abused
  • foreign material is inside the lens or
  • the lens is loose or completely off the track
Solution Follow all of the steps listed below.
  1. Perform a power reset on the camera.
    1. Turn off the camera and remove any optional memory card.
    2. Hold the ON/OFF switch in the ON position until the HP logo displays and then disappears.
    3. The camera is now reset. When the camera is turned back on it should prompt for the date and time.
  2. If the camera does not display an error after the reset and appears to be functioning properly, it is imperative to check and update the firmware. The firmware update corrects the lens positioning issue that can cause E104, E105, and E106 errors with the camera. Determine if an update is needed by following the steps below to check the current version of the firmware on the camera:
    1. Before turning the camera on, press and hold the Flash button.
    2. While the Flash button is depressed, turn on the camera. A Service Screen displays.
    3. Located at the bottom of the screen is an entry, F/W.
    4. If the version of the firmware is lower than 1.12, then the firmware update is required and should be performed immediately. See the HP document Recommended Firmware Updates for Photosmart 733 and 735 Digital Cameras .
Jun 23, 2008 • Cameras
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
