I have serial number 3568255
SOURCE: I need the owners manual for the Sony Cyber-shot DSC-T70
You can also download the manual here: Instruction Manual
SOURCE: Sony Cyber-shot DSC-W150. when powering on the
allienment with the mother board and also failure of the sensors of the lens unit,so contact sony service
SOURCE: why does my Sony cyber-shot
There is some steady-shot mechanism in camera lens that start vibrating due to some reason, this mechanism will be replaced to fix your camera issue.
It is not user level fix so take it in local camera repair shop.
SOURCE: how to disable the vibrate function in my sony
There is no option in the DSC-T70 Camera to enable or disable the vibrate option. The vibration in the Camera is a malfunction. The Camera may experience an issue where an abnormal internal vibration and an inability to properly focus and take pictures. Try the following troubleshooting steps and check if the issue can be resolved.
Follow the steps below to perform a manual power reset.
Turn off the Camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the Camera to remain without power for 60 seconds.
Re-insert the battery pack.
Turn on the Camera.
If the issue persists after the power reset, then reset the Camera back to factory default.
To reset the Camera back to factory default, select the INITIALIZE option under Main Settings 1 Menu of the Camera to OK. (HOME-->SETTINGS-->MAIN SETTINGS-->MAIN SETTINGS 1-->INITIALIZE-->OK).
If the issue occurs again, then service may be required.
Thanks for contacting FixYa.
We wish you a Happy Holiday Season.
