Can i change my razr v3i flip strip cable
SOURCE: White Screen on Razr, What is a "Strip Problem"
Before you open it and look inside it check to see if the magnetic switch is stuck. Check it with a kitchen magnet to the upper righthand corner of the keypad. There is a magnet in the lower righthand corner to activate it. Do some of the function work when it is closed? If they do then it is not the cable but the switch. Does the outside screen look the same as if it is closed then it is this switch? Could be a bad one, something stuck in there, or it could be stuck.
SOURCE: downloading games into razr v3i
hi everyone,
downloading mobile games via your phone takes
time and may come up into a more expensive one. so i suggest
downloading games via PC, and because this is what i've preferred to.
you can use this site for downloading games: www.zedge.com
installation:
after you have downloaded your chosen games, now we're going to install it from your PC to your V3i.
prerequisites:
1. your data cable(sometimes called as USB cable)
2. and your v3i - of course
getting ready:
1. connect your v3i using your data cable into your pc
NOTE:
before connecting your mobile device into your pc, you
must select "Memory Card" as your "Default Connection".
to do this, on your mobile select:
-> Main Menu
-> Connectivity
-> USB Settings
-> Default Connection
-> Memory Card
2.
a pop-up window will appear asking "What do you want Windows to do?" or
the like. on the icon list box select "Open Folder to view files" and
then click "OK", or you can ignore this by hitting the "Cancel" button.
if no pop-up window shows up, open your "Windows Explorer" and select your memory card from the list, open it.
3. if you're in, copy your downloaded games file from this directory of your Multimedia Memory Card(MMC):
[your MMC]\mobile\kjava
4. safely remove your mobile
games installation:
1. on your mobile, open "Games & Apps"
2. switch your storage device into your memory card
3. select [Install New]
4. from the list, select the game that you have just copied from your PC into your v3i
5. follow further instructions that will appear from your fon
6. there may have some instance you will encounter asking you to continue downloading, just select yes.
7. then it is done..just follow the instructions very carefully.
SOURCE: razr v3i cingular unlock subsidy password for t-mobile sim
You need to have the mobile unlock You can do this online at www.mobile2mobile.net or www.unlockitnow.com or take the phone to a mobile center or tech to have it unlock for a fee, unlocking is not a free service.
