It appears that the time display should always be visible. I was unable to find an owners manual on the Re-Run and a lot of people ask how do you even change the time on them. If there's a power saving or alternate display function in the owners manual, it will explain why the face goes blank.
Hi
You don't fix it. Hopefully you mean it's only 3 days old from being new and you can take back to the shop for refund/replacement.
ROM - stands for Read Only Memory and is basically the chip that all the software and information is stored on. This runs the watch and it's this that has failed. You could try reseting the watch by removing the battery and then replacing it.
Hey, this just happened to my nixon watch (I have the nixon housing - same setup as the lowdown) and what you have to do is simply hold in the light display button for about 3 seconds and the display won't disappear after the light times out.
Strap is attached to case by spring pins. Both ends of spring pin are inserted into holes into the case lugs, . Take the knife and push the spring pin end inwards to release the watch strap. Do not forget to rate, please.
