Question about Boating
Evinrude 40hp outboard
This 2001 Evinrude 40 hp outboard will run just fine, but sometimes the overheat alarm goes off while running fast. The engine isn't hot, and if it is shut off, then immediately restarted, it will run just fine. If it was really overheating, wouldn't the alarm sound, and the motor shut down? It may run for an hour, or just a couple of minutes, then the alarm will sound again, and shut down the motor. Everything checks out fine, when the mechanic looks at it. What is going on? Does Evinrude have a fix for this?
  • Boating Master
  • 3,632 Answers
First, the over heating alarm is for YOU to shut the motor down...
Replace the water pump assembly..(have a different mechanic do it!!!!!!!!!!!!!!)... they are NOT all created equal!!
Posted on Jun 13, 2017
6ya staff
SOURCE:
Anonymous
SOURCE: what is the correct fuel/oil mix for evinrude 4hp ?
the proper mix is 50 to 1 or 16 oz to every 6 gallons,in my little boat I put 4 quarts in the 48 gal tank and its been running for 22 years,your running way to rich and your plug is probaly fouled,take it out clean it up/dump your fuel and mix it right,thats a great motor you got,I hunted with it for years,oh yeah when you get started run it till all the smoke is gone or you will have carb problems ,if you dont have them all ready,a little carb cleaner wont hurt but get it running first,or all that trash will foul you out,have a great trip bartriley1
Posted on Jan 05, 2009
Anonymous
  • 65 Answers
SOURCE: evinrude outboard motor starter rope
most likly is missing a washer,has been reassembled incorrectly.take apart and check
Posted on May 08, 2009
Editor925
Dean
  • 285 Answers
SOURCE: Missing operators manual for Evinrude 2 hp outboard motor
Your best bet is ebay for a replacement user manual. Take a look around, you will come across one... For the meantime, gas oil ratio should be 50 parts gas to 1 part oil, i.e. 50:1. General care: Dont go full throttle for any length of time. Cruise of 3/4 throttle... Always flush engine after use in saltwater, including washing down exterior. Keep spark plugs in good order and check prop for fishing line wrapped around in near the prop hub. Otherwise, get a yearly service and have them check the water pump and replace as needed, get it tuned etc and gearbox oil changed.
Posted on Jun 20, 2009
thomasnee
  • 677 Answers
SOURCE: outboard motor overheating
Mate.The powerhead(engine block) is clogged.Don,t run it anymore untill its cleaned out or the motor will cook.Take the heads off 1st and see whats in the water jackets.It will probably be blocked.A build up of white 'gunk' is the main indicator.If thats the case,a complete cleanout is needed.Hope this helps
Posted on Jul 27, 2009
Anonymous
  • 86 Answers
SOURCE: Motor spits and sputters
If it is old enough to have points then I would check them and make shure they are clean and gapped at .020. if that is noth the problem then it sounds like a fuel issue. Either a weak pump or a dirty carb.
Posted on Aug 06, 2009
Why does my 1991 60 hp Evinrude outboard alarm sound and motor sputter occasionally?
when the alarm goes off is the engine getting hot, try running it in gear under load while tied up and with the engine cover off see how hot it gets and if the water i circulating all the time , might have cooling problem !
Aug 04, 2014 | Seloc Johnson Evinrude Outboards 1973 to...
usually in the head. Check a parts book.
Jul 11, 2014 | Boating
How do i replace the water pump in a 2005 150 hp evinrude outboard motor
Take the cowling off. Also drop the foot. There wil be a stainless linkage rod that runs the length of the motor that you will have undo to drop the foot. The water impeller will be inside a stainless casing that you will have to disassemble.
Aug 17, 2012 | Boating
I have no spark on 1989 7.5 evinrude outboard motor
Hi have you tried it with the stop switchl/button disconnected, if so you have only got the stator under the flywheel left to replace, regards Phil.
Jun 04, 2012 | Boating
Free download for repair manual for an Evinrude 1987 40HP outboard motor
My outboard motor is old and used.When I went to run it for the first time everything worked except when I went to put it in forward gear the boat went slowly but when I gave it more gas the engine just reved up but the boat wasn't going any faster.The motor is 40hp gale model.I think because it is bought used the prop is not the right one and it seems like it's slipping as I go faster.
I would appreciate any feedback on this problem.
Thax, Don
Apr 27, 2011 | Clymer Marine Maintenance and Repair...
Need wireing digram for 40hp evinrude boat with elc st
Check out the online info on this site, or on the search window type in 40 hp evinrude wiring diagram and go from there.
Jun 08, 2009 | Boating
40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
Apr 27, 2009 | Boating
Boating Logo
143 people viewed this question
Top Boating Experts
ray gallant
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Boating Expert? Answer questions, earn points and help others
