SOURCE: Kenmore # 63142 Fridge -- Water in Freezer
If water drains out, then there is always a blockage somewhere on drain line.
Defrost the unit completely to get rid of ice building inside drain lines.
If that does not work , then the drain line must be unlocked using a flexible shaft.
SOURCE: Tube that drains water from freezer is clogged
you should open the evaparator and from the compressor compartment use a cable from the drainge pipe to reach the evaporator by doing this you can clear the inside of the drainage tube.
SOURCE: Refrigerator top freezer model with
Click this link below:---
http://technoanswers.blogspot.com/2011/06/where-is-defrost-drain-tube-located-on.html
This should help.thanks.Helpmech.
