Whole camera vibrates and pictures are blurred
Use the scene setting mode to select a faster shutter speed, use either the high sensitivity or hi speed settings. See page 43 here
SOURCE: Sony dsc-t70 camara vibrates when turn on
it's actually a failure with the lens mechanism, I just experienced the same situation....Sony has another T20 that they had the same situation with and they offered to fix the cameras until July 2011..currently checking if Sony will fix this defect in this T70
what you are experiencing probably is best described by this article:
www.sonyinsider.com/.../dsc-t20-cyber-shot-camera-vibration/
SOURCE: help my sony DSC-T70 camera vibrates !
On Sony T100 and similar,
its the vibration canceling unit, i had the same problem.
if you have good hads you can fix it.( on your oun risk)
1) disasamble the camera, you will see black plastic box inside, this is he lens unit.
2) on the botom you see 2 scrwes, they are holding the CCD remove them and the ccd unit will come from the lens assembly
3) the next is the stabilizer unit it is the problematic one. it is located on the left side of the lens asebly and is held by 2 screws.
you can test it by puling out the cable connected to it (the conector is just under the lens) and verifign that the problem is solved. ( you can leave it this way it will shoot fine just without the anti shake)
4) to fix it take it out ,remove the plastic cover, you see the lens on a plastic mount it should be glued to the magnet under it. the problem is that the glue fals apart.
remove one of the pins on wich it slides, and take the lens and the magnet out.
5) reglue the magnet and reasemble the camera.
6) power up and test, for me that solved the problem
if you need more help you can mail me at adisarit(et)yahoo(dot)com this is spam mail so be prepared to wait a few days for reply.
i have a document with pictures explaining the process ..
SOURCE: Screen vibrates intermittantly. Also buzzing noise.
This is a problem with the lens gyro we can keep it from shaking it requires the camera to be taken apart and amodification done to the lens repair cost 65.00 in most cases.
SOURCE: Camera vibrates when it is turned on therefore pictures are blurry
seems the motorised lens of your Sony have issue.
should get it rectified without delay if still in warranty.
contact the vendor and sony support.
SOURCE: My sony cyber shot DSC T70 vibrates. Sometimes I
