Samsung HT-BD2R 7.1 Channel Blu-ray Home Theatre System Theater System Logo
s
snehal bhatt Posted on May 12, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is to be done as My samsung home theatre having model numbe HT XQ100 is not repairable then what should i do now?
John Bolton
Level 2:
  • Expert 87 Answers
  • Posted on Jun 13, 2014
John Bolton
Expert
Level 2:
Answers
87
Questions
0
Helped
22702
Points
156
5 Related Answers
Anonymous
  • Posted on Mar 30, 2009
SOURCE: Samsung HT-BD2R 7.1 Channel Blu-ray Home Theatre System
If your television has RCA style audio/video output you can use an audio RCA cable (red & white connectors) and simply plug from the 'output' of your television into the auxilliary input on the back of the HT-BD2.
Then select AUX on the HT-BD2 remote, whenever you wish to listen to the television audio.
Anonymous
  • Posted on Apr 14, 2009
SOURCE: rear check message on HT-TXQ120 samsung home theatre
Looks like it is to do with the rear wireless speaker. Now, my problem is over. Its gone. I first turned the reciever on and then turned on the rear speaker wirel less on. No rear chk in problem now. Hope this helps. R.
Anonymous
  • Posted on Jun 09, 2009
SOURCE: HOW DO YOU RESET A SAMSUNG HT-WX70 HOME THEATRE
According to the instruction manual you turn off the unit and press the Stop button on main unit for at least 5 seconds. Didn't help me with my problem (shutting down for no apparent reason) maybe it will help you with your problem.
Anonymous
  • 312 Answers
  • Posted on Feb 05, 2010
SOURCE: Insignia Remote Code Needed for Samsung HT-X40
Many remote control codes can be found at InsigniaProducts.com. Search for your Insignia product model number and click on the Support tab.
Anonymous
  • Posted on Mar 31, 2010
SOURCE: Hi My samsung HT-XQ100 home theatre system will
I have the same problem, looking for a solution as well..
5helpful
When I turn on the unit I get a symbol that is a circle with a diagonal line through it and then the unit turns off. Any ideas? (Samsung HT XQ100 Home Cinema)
Your fan is bad.
The system is intelligent. It knows it will overheat without a fan. It also knows there is a problem with the fan, so it throws its self into self-protect mode to keep from overheating.
Have a tech check your fan.
;o)
1helpful
2answers
Soundproblems on my Home Theater System
http://downloadcenter.samsung.com/content/UM/200702/20070207171859140_XQ100TXQ100_GB.pdf
Suggest you go back and check all connections with speakers that wires are connected with input properly I have given you web address for manual usually find wires are not bared back enough for connection test each one individually with a tester to make sure there are no broken wires.
1helpful
My device wont turn on (samsung HT-XQ100)
it mite from the overheating its happen to me
3helpful
Tengo un ht-xq100 pero esta bloqueado pues en el display aparece un circulo atravesado por una barra no accede a ninguna funcion y alos 15 segundos se apaga automaticamente
I have sumsung HT-XQ100 DVD player it is overheating even it is in cooled room .... I'm afrid to keep it running for long time ...
could you please helpe my ...
Regards,
HDMI conection
Hi.
Connect the Home cinema and the TV with the HDMI cable. When you turn it on, first turn on the TV and then the home cinema. I hope this works.
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
