Intermatic Inc. ST01C Digital In-Wall Timer Logo
A
Anonymous Posted on May 12, 2014
How to set time on GE stoves - Intermatic Inc. ST01C Digital In-Wall Timer
2helpful
I can't get my clock set on my GE stove model # JB645DT1BB It said to hold for 3 seconds to change the time but it doesn't change. HELP Please
To Set the Clock
The clock must be set to the correct time
of day for the automatic oven timing functions
to work properly,The time of day cannot be
changed during a delayed cooking or a delayed
self-cleaning cycle,
1. Touch the Clock pad twice.
For models without a Clock pad:
Hold the + and - pads for 3 seconds.
2. Touch the + or - pads.
If the + or - pads are not touched within one
minute after Step 1, the display reverts to the
original setting. If this happens, repeat Step 1
and reenter the time of day.
3. Touch the Start/On pad until the time of
day shows in the display. This enters the
time and starts the clock.
To check the time of day when the display is
showing other information, simply touch the
Clock pad. The time of day shows until another
pad is touched.
http://www.managemylife.com/mmh/owner_manuals/138431/GE-Free-Standing-Electric-1112529L
Ge oven membrane panel
Order GE range/stove/oven parts today. We ship GE range/stove/oven parts on time or your order is free. Return any GE range/stove/oven part for any reason for one full year. Customer service for GE range/stove/oven parts is available 7 days a week. More than one million parts available. We stock the GE range/stove/oven parts you need for immediate shipment. We have more than 200,000 high-resolution part photos.
Rachellewis250@I have mislaid my Stoves 720 EF manual. How do I set the timer?
There are five buttons. from left to right they are Minute Minder, Cook Time, Ready Time, Plus, Minus.
To set the time of day press the Cook Time and Ready Time together and then use the plus and minus to set the time. Use the Minus button alone to change the alarm tone.
To set the Minute Minder, press the button and use the Plus and Minus to set the time period. To cancel use the Minus to ge back to 00.00
I cannot turn on the bottom oven on my stoves and I believe it's because the clock is incorrect and I don't know how to change it.
To set the Minute Minder, press the button and use the Plus and Minus to set the time period. To cancel use the Minus to ge back to 00.00.
I have a GE electric profile stove. The range is working the stove is not. What should I look for.
the electric profile stoves have a set of electronic relays in the top of the stove where the digital settings are. the most likely problem is the control module that allows the electrical power to pass through it --is bad or damaged. also there may be a fuse link that blew out. The ovens and stove tops are usually on seperate relays. If the relays are solid state (soldered) you will need a technician to replace the relay. If it is just screwed to a panal board you could replace it yourself. Do you have the papers that came with the stove?? if so there should be information on the parts and ordering. also, there should be a schematic diagram of parts location on the stove. This will show you where the relays are located and which is the oven and stove top. or you could go online to www.ge.com and locate the parts and diagrams for replacement.
GE gas stove
sounds like a bad bake ignitor(uneven heat,long cook times, long preheat times, perhaps even gas smell while cooking)as far as the heat from under the clock assy thats the normal vent( nedds to release heat somewhere, not a problem
2answers
GE Kitchen Range
have you tried clock then setting it
2helpful
Stove top pilot light
I have a GE Gas Stove XL44 the stove top buners don't light by themselves without manual lighting. When I turn on the buner knob the buner doesn't click. Also I used my self- cleaning oven for the first time and stopped it before the time was up after that is when the stove top buners wouldn't light by theirselves.
GE Profile JGB916
LP or natural? Are the valves set correctly for such and the regulator value changed if a different gas is used than what the manufacturer set the stove up as?
Good Luck...
Top Intermatic Hardware & Accessories Experts
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
