Amana Comfort Zone 12M32PBEH Air Conditioner Logo
A
Anonymous Posted on May 12, 2014
My amana does not kick and belows hot air - Amana Comfort Zone 12M32PBEH Air Conditioner
Amana air unit does not kick in, compressor hums
Hi Bowmunster,
Sounds like it could be a couple of things - the run capacitor could have failed or the compressor has seized - having said that a wire could have burnt off the compressor terminals
Good luck
1helpful
Heater, ac and fan speeds all working fine. Compressor not kicking in...just auxiliary heat working.
Outside temp too low, so outside thermostat and it's settings will not allow the heat pump to work. But insist on the ausilary heat to work instead. Heat pumps usually do not produce enough heat when below 40F outside temp. If you have Gas heat, it may be more economical than the heat pump below 40F. If electric auxilarry heat, it may compete at 32F. Talk to your dealer, installer, or manufacture.
1helpful
Rooftop RV Air Conditioner: temp outside 90 or above. compressor kicks off ....
It sounds like maybe an overload for the compressor is tripping and resetting once the compressor cools. Possibly due to a low charge.
2helpful
2answers
Its 15 degrees outside and my amana unit is off. every so often it kicks on by itself and runs for about 10 seconds then shuts off again. while it is running the control panel flashes FP, what is it trying...
I was wondering the same thing about our unit until I found the specs online and read that it has freeze protection. When the temp goes below 40 degrees, the fan comes on to prevent damage to the unit.
My heater stoped working. The houst has been sitting for 2 years and when I used the AC, I had to put a start cap on it for it to work. Now that its winter, the heater will not work. When I turn it on the...
did the start cap fail again didnt say if condenser fan was running if fan not running compressor will over heat and turn off or if coils of condenser are dirty wont let air pass thru
1helpful
Amana Cooling Condensing Unit fan won't kick on
be aware that not repairing this asap that you are causing yourself more problems First I would change out the fan capacitor and see if this could be the problem. Secondly if the capacitor isn,t the problem change out the motor . By continuing to allow the system to cycle like this the compressor will take a dive on you costing more . Good Luck
Dave
1helpful
My Amana heat pump model PHD60C02F1 Keeps tripping the circuit breaker
Is this kicking the ground fault on the cord or the breaker. If it trips breaker could be bad breaker. If it trips quickly it is a short in the unit. Russ
Heater not blowing hot air display says lo
when the coils freeze up , from intake of outside air, when using the heat pump mode, the unit will try to defrost the coils before going back to heat mode. mine did this alot. does it kick back to heat after a few mins? also after 2 years , mine started having issues with the exhaust blower control and would go into warp mode and bang noise.seems like common issues for this unit.whether the amana, or haier version.
Top Amana Heating & Cooling Experts
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
