The issue you described with your RM Toledo 110 Fan oven can be caused by a few potential factors. Here are some possible explanations and troubleshooting steps you can try:
- Overheating or thermal cut-out: If the oven heats up and then cuts out after a short period, it's possible that the oven is overheating and triggering a thermal cut-out safety feature. This could be due to a faulty thermostat or an issue with the oven's ventilation. Check if the oven's vents are clear and not blocked by any obstructions. Additionally, you may need to have the thermostat checked and replaced if it's not functioning correctly.
- Electrical connection issue: It's possible that there's an electrical connection problem causing the oven and clock to intermittently lose power. Inspect the power cord and plug for any damage or loose connections. Ensure that the oven is securely plugged into a stable power outlet. If the issue persists, it may require the attention of a professional electrician to investigate and repair any underlying wiring issues.
- Control panel malfunction: A malfunctioning control panel or circuit board could cause the oven and clock to intermittently lose power. This could be due to a faulty component or a loose connection. Contact the manufacturer's support or a qualified technician to diagnose and repair the control panel if needed.
- Power supply fluctuations: In some cases, unstable or fluctuating power supply can cause appliances to behave erratically. If you notice other devices or appliances experiencing similar issues in your home, it may be worth contacting your electricity provider to investigate and resolve any power supply issues.
Given the potential safety risks involved with oven repairs and electrical troubleshooting, it's advisable to seek assistance from a qualified technician or contact the manufacturer's support for further guidance. They will have the expertise and knowledge to diagnose the specific problem with your RM Toledo 110 Fan oven and recommend appropriate solutions
