LG X-Note LM50 Notebook Logo
s
sselvam Posted on May 11, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bios reset Not function F2 & F12 key. bios reset. Already removed and check by CMSO battery.
Ankit Chandel
Level 2:
New Friend:
  • Expert 141 Answers
  • Posted on May 11, 2014
Ankit Chandel
Expert
Level 2:
New Friend:
Answers
141
Questions
Helped
29329
Points
375
Try f1 or alt+h
Testimonial: "no a beep sound is there and again still F2 and F12 not function"
  • Ankit Chandel
    Ankit Chandel May 11, 2014
    start and press button (for bios menu)
Have a dell latitude D620 that is password protected in such a way as to prevent even the F2 and F12 keys to function. Can you supply a way around this please
You may have a USB keyboard that is not recognized by the BIOS on powerup, but is later recognized by Windows when that starts running. Try connecting a keyboard with a PS2 connector, enter F2 on startup and set the BIOS to enable USB devices in BIOS. If this still doesn't work, then keep a PS2 keyboard around in case you ever need to activate F2 or F12.
Bios setting probleme
you can not press the F12 or F2 Key at startup ....You need to hold the key down abd bios will open of boot order if F12 is pressed.
So hold the key down(F2,F12) then press the power key...keeping the F key pressed down.
Good Luck
2answers
Linux mint 12 won't boot from CD
Restart your computer, press repetedly a key to enter BIOS, normally Del, go to Advanced BIOS Features probably and change to boot primarly from CD/DVD (1st Boot Device CD/DVD , or something like that), save and exit BIOS, and restart your computer with Linux Mint CD inside. Be aware that if you make wrong changes in BIOS, you could damage your computer.
Please advise how to reset the biose on vgn-s28gp,i try to find reset jumper but i did not find out please help. aqeel.
Not sure which key Sony used but the easiest way to reset the Bios for a laptop is to start teh computer and go straight to Bios and select to restore Default settings. All Bios setups ahve this option. It is normally the F2, Del, F10 or F12 key right after you see the initial splash screen after tuning the computer on. The only other option I can think of without tearing the system open would be to remove the power cord, the main battery and the Bios battery if you have access then put it all back. In some models you can remove teh covers from the hard drive or Ram on the bottom of the computer and get to the Bios battery to remove it. I know a lot of HP models have that so it may be an option with the Vaio.
1helpful
2answers
I am unable to open bios. Actually I wanted to change the boot sequence for HARDDISK TO CDROM but could not open bios. What to do?
Hi ranjanaghosa,
I see that you need to change the Boot Sequence on you Thinkcentre M55e but could not get in BIOS right.
to be able to change Boot sequence you can also try on tapping f12 as soon as you power the machine ON untill you get the Boot Menu you can also change boot sequence from there.
To get in the BIOS on a desktop you need to keep on tapping F1 as soon as you power the computer ON, but if still this does not work you can try Tapping on the Delete key to get in the BIOS, getting in the BIOS depends on the motherboard some use f1 to get in the BIOS some use Delete to get in the BIOS on desktops.
but using the F12 key can be done as well if the F1 or Delete key does not work.
I hope that this helps.
Have a nica day,
mvincentc
How do I enter into BIOS on a Systemax SYS651M03 pc? Windows XP will not start and I need to change the boot sequence to boot from CD, but can't find the right key to open BIOS on startup.
Usually delete, might be f2, to enter the boot order I gauruntee it's f12. If the bios is passworded, you are screwed. Try reseting the bios by unplugging the unit, remove the bios battery for atleast 10 secs, then put it back. If it's still passworded...see above.
2helpful
Laptop not used for some years. could enter bios OK to reset Replaced U/S CMOS battery with no problem. Restarted............ Message press F1 ibm bios setup press F11 to invoke IBM product recovery...
I received an IBM laptop with same issue a few months back. The error message due to the drained out CMOS RTC (coin-cell battery), which retains and other BIOS settings.
The system is OK and all you have to do is to get the CMOS/RTC battery replaced by the a professional.
Good Luck!
CreativeTECH
2answers
Which key to press at startup to gain access to BIOS E2180 Intel
There are a number of keys used to access the system BIOS at startup. F2 is probably the most common, but I see you've already tried that. I've also seen the ESC and DEL keys used, so try those. If that doesn't work, start working your way across the F1-F12 keys.
Hope this helps. Please take a moment to rate this solution. Thanks.
5answers
Can't enter BIOS setup with F2
Try using another application that has a use for the F2 key. I'm not totally convinced that your keyboard is good. It is possible for just one key to fail. Happens quite often.
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
