I think ice makers have a power button either a toggle switch or when you look at the top of the ice cube maker you will see a stainless bracket about the size of a pencil lead and as long as the ice cube maker. If the bracket is up then the ice maker is off. It should be down touching or almost touching the cube maker. Another problem could be that you have no water flow to the maker. Line may be frozen. If you find the toggle or push the stainless arm bracket down you should hear the water pump Buzz or hum. Try turning it from off to on but wait about 2 or 3 mins between switching. I hope my info was relevant to your problem. Make sure your water pump is working it's located on the back bottom where the water line goes in
