Canon PowerShot A75 Digital Camera Logo
A
Anonymous Posted on May 10, 2014
Connect usb laptop - Canon PowerShot A75 Digital Camera
I just bought a coolermaster x-lite II laptop cooler and when I connected to my laptop there is no power, why?
In what way is it connected to you laptop?
From what I understand, you have to connect it through the mini-USB port to an USB port on your laptop. The other USB ports are for using it as an USB hub.
Kind regards,
Jon Erik
1helpful
Why Canon IR2016J not detecte in my laptop windows 7?
Canon ir-2016J not supporting for print. so it will not detect USB. USB can be used for only updating mechine system software.
2answers
2answers
How do I set up a d-link dub-h4 to my laptop I have a power connection, a connection on the rear of the hub-4 going to an adapter connecting to the ps/2 connector on the laptop. Do I need one of the...
The connection on the rear of the hub should go to a USB connection on the laptop, not a PS/2 connection. A PS/2 to USB adapter is used to connect a PS/2 keyboard or mouse to a USB connection.
1helpful
Usb 1.0 or usb 2,flatbed scanner compatability
Find a USB device, such as a memory-stick, that is "USB 2.0" and connect it to a USB port. If Windows XP pops-up a window ("this device will perform better when connected to a USB 2.0 port"), then you have connected it to a USB 1.1 port.
Yes, you can connect a scanner, if it has a USB connection. Not all laptops have a parallel-port ("old-style" printer) port, but some scanners require a parallel-port.
1helpful
HP Printer Usb port in my Acer Laptop , shortcircuits my house
hello
Try using external USB HUB (POWERED) Adapter. It might fix this issue.
Use an other USB cable and see.
If the problem still exist do not plug in the printer again, you may damage your USB port or even burn your laptop motherboard.
hope this helped
TekSpotDotCoDotUK
Unable to connect mouse to acer laptop
Before you connect your wireless mouse USB adapter to your laptop you'll need to install the software first, after the software is installed follow the steps to connect the wireless mouse USB adapter, this will keep the instalation wizard from popping up.
Usb broadband modem
Im not aware of any gadgets, but you can always use the USB stick on one laptop, share the internet connection, and connect the other laptop throught the shared connection.
That would require your laptops to be networked, either by a crossed cat cable or with regular switching or routing.
Usb 2.0 error
did you connect directly to your laptop or you connected via external USB Hub?? Your notebook model should support USB 2.0 ...so it should not face the problem you post..unless you're not connecting it directly.
takecare.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
