Http://support.dlink.com/emulators/wbr2310/lan.htm
look at dlink for mor info
SOURCE: i cant istall dlink dwl
be sure to check every point on this TIP
to connect to "prescribed site" (I assume the default router IP address 192.168.0.1) you must be on same subnet and connect using a cable to router.
Consult Quick install Guide
or follow user manual Page !0 instructions:
First, disable the Access the Internet using a proxy server function. To disable this function, go to Control Panel > Internet Options > Connections > LAN Settings and uncheck the enable box.
Open your web browser program such as Internet Explorer. Type the IP address of the DWL-2100AP in the address field (http://192.168.0.50) and press Enter. Make sure that the IP addresses of the
DWL-2100AP and your computer are in the same subnet.
If you need help in the matter let me know and I'll send you instructions
SOURCE: how to connect dlink dwl 3200AP with dlink dwl
make a repaeter mode
and ip would me same range
SOURCE: how to access Dlink Set up page ?
i can't able to connect the http://192.168.0.50 please give me solution.
SOURCE: I change The IP to 192.168.1.102. and if I connect
after reset the wireless device you can connect only through 192.168.1.1 or 192.168.0.1 IP address.
SOURCE: is there any limit for wireless D-link DWL-2100 AP
D-Link AirPlus Xtreme G DWL-2100AP Wireless Access Point provides speed upto 108Mbps, which is the maximum wireless signal rate derived from IEEE Standard 802.11g specifications. However, the actual speed depends upon the wireless network environment, setup and devices.
For further details please refer to DLink Official Product Description
