SOURCE: need to know the kind of oil or grease that goes in transmission
engine oil is sae 30
the the gear box I think is a 90wt
SOURCE: Need to obtain a new belt and pull rope for my Tiller
you can get a pull rope at wal-mart.measure the belt and any parts store or place that sells lawnmower belts should have one.if the rope broke close to the end knot just pull the end knot with some needle nose pliers.once you have all the old rope out lay the old rope pieces on the ground and cut the new rope to match it as far as length.turn the pulley that the pull rope goes in six turns counerclockwise.then turn the slot the knot was in to the hole the pullrope goes thru and fish it thru then pull it up and out with apaiar of needlnose have someone hold the pulley until you tie a small knot in the end of the pullrope the hold the pullrope and let it pull it in.you might have to cut some off at the handle if its still too long.to do this pull some rope out and tie a quick knot so the rope can't slip back if you let it go.
SOURCE: I have a MTD Yard
If you go to this webpage:
http://www.mtdproducts.com/webapp/wcs/stores/servlet/OwnersCenterView?storeId=10500&catalogId=20500&langId=-1
....you can enter your model number and serial number to download the manual.
SOURCE: need belt and bushing seals for (tiller)
try looking for tiller model 410 or 420
#215-410-019
the 135202 number is the b&s motor number
SOURCE: i have a mtd yard
remove the sediment bowl off the bottom of the carburator and dump out any moisture,then replace it and see if you can keep it running with the choke partially on,if so then you have a lack of fuel due to a dirty carburator,if this doesnt help,the gasoline cap can get bad and go shut and vapor-lock loosen the cap and also try this
