Saeco 7p Plus. Program selections. Can it be done without the handheld programmer? Have machine want to set prices.
Saeco 7P+ pricing is set mainly without programer. The machine has 2 pricing points so the price of the beverages can be set to one of the two prices. To change which price point the beverage is assigned to you need to use the programmer. Price point 1 is the lower price and price point 2 is the higher price.
To change the price on all beverages, make sure there is power to the door. On the inside of the door the is a little circuit board with two red buttons. On the bottom side of that board is a little button that is normally black. Press this button and the screen should read 000. If you push up (which is the 1st beverage button) the screen will read 001 this is price point 1. Press enter (4th beverage button) to change the price and use the up and down keys (down is the 2nd button down).
To change price point 2 press cancel (3rd beverage button down) if your in price point 1. If your in the menu at 001 just press up again and the screen will read 002. Repeat steps above to change.
Normally all beverages are set to the same price, if this is the case than change both price points to the same price.
It is better to set price point 2 first as price point 1 won't adjust higher than what price point 2 is set at.
When done which the machine off then back on.
Have fun.
