What is the warranty on my new DiMAGE Digital Camera?
For the following cameras: Dimage PIC, Dimage V, Dimage EX 1500 (ZOOM or WIDE), RD-175, Dimage RD-3000, Dimage 2300, Dimage 2330, Minolta 3D-1500, we offer a 1 year limited USA warranty. Please see warranty details below.
For the following cameras: DiMAGE 7, DiMAGE 5, DiMAGE S304, DiMAGE E201, DiMAGE S404, DiMAGE X, DiMAGE 7i and DiMAGE F100, DiMAGE F200, DiMAGE F300, DiMAGE 7Hi, DiMAGE S414, DiMAGE E223, DiMAGE X, DiMAGE Xi, DiMAGE Xt, DiMAGE A1, DiMAGE Z1, DiMAGE G500, DiMAGE X20, DiMAGE E323, and DiMAGE Xt Biz we offer a 1 Year limited international warranty. Please see international warranty details below.
(All current Minolta and Konica warranties will continue to be honored by Konica Minolta.)
MINOLTA CORPORATION U.S.A. LIMITED ONE (1) YEAR WARRANTY-
Minolta Corporation 101 Williams Drive Ramsey, New Jersey 07446 (לMinoltaמ) warrants that the product set forth below, IF PURCHASED IN THE UNITED STATES OR ANY ISLAND IN CARIBBEAN SEA, will be free from defects in materials and workmanship for the period of one (1) year from the original date of purchase under the following terms and conditions:1. To obtain service under this warranty, send or deliver this product, within the warranty period together with this warranty certificate, to any Minolta regional office or Minolta authorized warranty service center, you must also present proof of purchase showing the date and place of purchase and, if not prohibited by local law, pay a handling fee. 2. If, upon inspection by Minolta or a Minolta authorized warranty service center, the product is proved to be defective, it will be repaired without charge using if necessary, new parts or comparable used parts which have been fully reconditioned, and returned to you. Where not prohibited by local law, a freight charge may be imposed for the return of the product to you. The warranty period for replacement parts shall extend for a period of six (6) months following the installation of same or for the remaining period of this warranty, whichever is longer.3. This warranty card does not apply in the following cases:(a) damage to the product due to mishandling, alteration, accident, impact dropped, sand and/or liquid or moisture damage, tampering, battery, or chemical corrosion, failure to follow operating, maintenance or environmental instructions prescribed by the applicable instruction manual or shipping damage; or,(b) damage caused during service performed by other than Minolta or a Minolta authorized warranty service center; or,(c) if the product has had its serial number(s) or other identifying data removed; or,(d) damage, defect or unsatisfactory performance caused by the use or attachment of lenses, flashes or other accessories not manufactured or distributed by Minolta. 4. ANY IMPLIED WARRANTIES FOR THIS PRODUCT, INCLUDING WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR USE OR PURPOSE, ARE LIMITED IN DURATION TO THE PERIOD OF TIME SET FORTH BELOW FROM THE DATE OF PURCHASE,
I have had the same problem for like 6 months. We had the camera for a
little over a year, worked great, took good photos and one day it
wouldnt turn on with fully charged batteries.
We put in fully re-charged batteries, turn the power on and all that happens is a blinking battery icon in the top window.
Checked the battery terminals...they look good.
Swapped out the card...didnt work.
Tried 3 different brands of re-chargeable batteries...doesnt make a difference.
We would really like a solution this so we can stop using our grainy camera phones.
Please anyone HELP!
Thank you, Ronnie.
I have been having same problem with my dimage 7i with batteries seemingly not good enough so I purchased brand new NiMh charger and two sets NiMh 2400mAh and 2500mAh Powertech cells. Despite having them freshly off the charger the 7i would shut down after few minutes use displaying flashing battery symbol. The unloaded cell voltage seemed acceptable- 1.2+ to 1.3 approx after charge. Thinking the cells still weren’t "good enough" I configured an external voltage source using DiaMec sealed lead battery 6v 1.3AH/20R and put a 1 Amp (full scale deflection) real anolog meter in series to monitor the current. What I saw was the current ramping up to about 150mA and then returning to zero. This can be symptom of equipments over-current protection circuit cutting in to save the rest of the camera. I decided it had to be looked at by proper Minolta service agent. I told them these details concluding it looked like over current. Later the service person said they had checked one pcb, no change, and then another and deduced it had fault. I paid $430 + plus original $65 quotation fee. I now have camera back again and charged up my new battery sets again and was surprised at how short the time was before the camera cut out again with the flashing battery symbol! So I went through the "must be dud batteries" again and actually found one cell had low(er) voltage than others. I constructed battery test circuit - 1 amp meter, nominal 1.25 ohm resister expecting to draw something less than 1 amp (it was around .7 to .8 in practice) to show cell capacity to maintain nominal voltage under high current. The low voltage cell when placed in test circuit immediately dropped down heading to .2 -.3 amp. It was stuffed. Now armed with known good set of batteries, fully charged, I found the camera only ran for approx 4 minutes of repeated use including 6 flash shots. That doesn't seem very long. So I connected my external sealed lead 6volt cell again to the external power in point with the 1 Amp anolog meter in series. What it showed was that upon switch-on the current drawn hovered around 800 to 830 milliamp (.8 to .83 amp). The needle was erratic which I think is very unusual for digital gear. With no action taken the LCD screen turned off and the current reduced approx 100 mA. With still no further action the current dropped off to near zero in the camera rest state. When "idling" at the 800 - 830 mA drain, raising up the flashcover caused the current to increase to around 950 to 980 mA. I have a technician background but nothing to do with cameras (radio & TV). To my recconing, having a standby current of around 800-830 mA out of AA cells seems excessive. I'm going to take that camera back to the service agent with these findings. I think it is still faulty with excessive current draw but I have nothing to compare against such as service data or another working 7i camera.
If anybody knows what is the initial standby current after switch-on I'd be interested to know.
Regards
SL.
