If toner is new- check that it is in correct position- still printing fine? Error message continues, disregard msg- they are trying to sell you more ink
Must be an aftermarket or refilled toner cartridge. These toner cartridges have a chip on them that must be changed when refilling or remanufacturing the cartridge. It looks like you got a cartridge where the chip has not been changed. I would return it for another cartridge.
Good Luck and Thank You for using Fixya.
Wheatland Services
This can sometimes be related to paper dust interfering with a sensor. A burst of canned air can fix the problem. Just pull out the toner, open all of the covers and spray air into all the little crevices. You might want to do this outside, in case toner is loose in ther, so as not to make a mess.
Hi The AP message indicates thet the dev is so low in toner that the machine has to go into a full cycle mode to get the toner levels up. The error code is telling you that one cycle is not enough. you will have to turn the copier off/on and cycle it at least one more time....more if neccessary
unplug printer
remove network card and cable
plug printer in & turn on.
wait for boot sequence
unplug printer
reinstall network card and cable
plug in / turn on.
If it wont calibrate, you have a bad toner cartridge.
A CH code means the toner cartridge is not being sensed. Could just be not seated properly. Open the front and remove and reseat the toner cartridge. It may be empty also.
