You may need to send in unit for service because your unit is unable to go to sleep mode when the signal cable is disconnected or the PC is turned off. Please call ViewSonic Customer Care for support.
Although this will not hurt the monitor, you just need to apply an active video signal to get a display correctly. However, it will not work as expected to go into sleep mode. You'll need to call ViewSonic Customer Care to get this taken care of.
SOURCE: viewsonic lcd tv 37"
try to check the RAM, video card, or processor maybe it is not properly inserted to the slot.
SOURCE: Hi FixYa A query about my
If you have an older graphics card the signal will still be searching for a monitor. Contact Viewsonic and they will get you a non DDC adapter.
service.us@
viewsonic.com
or
T: (800) 688-6688
Good luck
Joe
SOURCE: White colour displaying as blue, and red colour
It's simple i had the same problem the solution is u go to the settings menu in the monitor and reset the options and settings.
WIRING INFORMATION 2001 Subaru Legacy
WIREWIRE COLOR LOCATION
12V CONSTANT WIRE WHITE Ignition Harness
12V IGNITION WIRE GREEN Ignition Harness
12V ACCESSORY WIRE YELLOW Ignition Harness
STARTER WIRE WHITE/BLACK Ignition Harness
POWER DOOR LOCK (-) WHITE Harness In Driver's Kick Panel
POWER DOOR UNLOCK (-) GREEN/RED Harness In Driver's Kick Panel
PARKING LIGHTS (+) ORANGE At Light Switch
DOOR TRIGGER (-) PINK/BLACK In White Connector Behind Fuse Box
TRUNK TRIGGER (-) YELLOW/BLUE In White Connector Behind Fuse Box
TRUNK RELEASE (5-wire) LT.GREEN/YELLOW At Motor In Tail Gate
FACTORY ALARM ARM (-) Factory remote only
FACTORY ALARM DISARM (-) Factory remote only
TACHOMETER YELLOW/GREEN At Ignition Coil
BRAKE WIRE (+) WHITE/BLACK At Brake Pedal Switch
HORN TRIGGER (-) RED/GREEN Harness At Steering Column
LEFT FRONT WINDOW UP BLUE/RED At Driver Window Motor Inside Door
LEFT FRONT WINDOW DOWN BLUE At Driver Window Motor Inside Door
RIGHT FRONT WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
RIGHT FRONT WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
LEFT REAR WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
LEFT REAR WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
RIGHT REAR WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
RIGHT REAR WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
