SOURCE: Printer status offline
I just ran into the same problem. The computers on the network that were running XP were showing the printer as "Ready", but all of the computers running Vista were showing the printer as "Offline".
After trying a number of solutions that I found on other message boards, I accidentally discovered that the problem was an IP address conflict. It seems that the server changed the address on the printer, which didn't bother the XP machines but brought the Vista machines to their knees.
Press and hold the blue button (HP called it the "Go" button) for 5 seconds, which will print a configuration report. In the TCP/IP section you will see the IP address for the printer. Next, open the Printers window, right-click on the P2015 and click Properties. Click the Ports tab. Find the port that is checked and click the "Configure Port..." button. If the "Printer Name or IP Address" field differs from the IP address on the configuration report, change it to the one on the report. It took a few seconds after hitting OK for the computer and prrinter to link up again, but that solved the problem for me.
SOURCE: Can't print because of Error-offline status.
I found out that the IP address on the printer was different from the IP address that was available when the printer was first installed. After spending days trying to fix this, it was resolved in less than two minutes.
Go to the Printer Folder in the control panal and choose to Add a Printer. You will see the option to add the new printer ( wireless). Chose to install, and it will install the printer under the new IP address. It worked instantaneoulsy.
You also need to make sure the IP address is inputted into the printer ( check your guide for how to input the IP address)
What I dont know how to do is to keep the IP address static. Afger, it is not practical to do this each time it changes. If only the last digit changes, it may be as easy as switching to the printer available under the current IP address.
Cheers,
DeniseA
SOURCE: printer offline
first of all when you upgrade your computer you deleted all your program thats why your computer cant recognized your printer. do you still have the disc the came with the printer if you do dont worry the only thing you should do is restall the program by inserting the disc into the computer and then follow the steps in the screen.
SOURCE: I had my printer (hp psc 1200 series) try and
You need to go ahead and simply refresh a service known as "Print Spooler"
here's how you do it..
for Windows XP:
>> click on start
>> click on run
>> type in " services.msc " and hit enter
You will see a list of service names alphabetically arranged on the right hand side..
From there look for the service name "print spooler"
>> right click on it
>> click on stop
wait for 10 secs
>> right click on it again
>> click on start..
>> restart the computer..
>> you will find your document deleted :)
plz rate if you find it helpful. thank you
