Even at maximum brightness it's still too dim
SOURCE: DELL 1907FP MONITOR
There were no screws on the back of my monitor so that was not an option for me. I figured I didn't have much to lose, so I took a very thin and small screw driver and pried the on-off button right out of its socket, which does break it. To the left, inside the hole,you can see where a tab on the button pressed against a small circular inner button. I pressed that with the screwdriver and the monitor turned right on. I replaced the button for the sake of cosmetics and will never touch it again. If I leave the monitor for any extendd period of time I will simply unplug it.
SOURCE: dell ultrasharp 1907fp bad contrast
I have seen a few of these monitors that when the display is dark in certan area's this usually indicates that one of the CCFL lamps has gone bad or there is a problem with the Analog/Digital Board, you can find the boards on ebay, but be VERY Certain that the board you order is the same that you take out of the monitor, as there are a lot of monitors that use the same simular boards but they are all different.
