The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
SOURCE: Probllem connecting to my DLINK DSL-2640U
I have the same problem but what you need is that :
- Enabled the DHCP
- Reset Your IP and DNS
- After that turn off your Wirless and turn on it !
- Buy a wirless "Windsurfer" is just 1£
I hope that work ! :-D
SOURCE: How to configure my Airtel
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
SOURCE: My D-Link DSL 2640U modem
You could probably log into the router interface and chnage the wireless settings and re-name the network. This might work.
Hope this helped.
SOURCE: I have a Dlink dsl
try to hard reset the router by pressing the reset button on the back for about 10 sec and after doing that try to make sure that you are hardwired to the router. then try to access the configuration page again. this should work.
