Compaq Presario Notebook Logo
A
Anonymous Posted on May 08, 2014
Status error code 10008 - Compaq Presario Notebook
1helpful
Windows Boot Manager message: Windows encountered a problem communicating w/a device connected to your computer. Error may be caused by unplugging a removable storage device such as an external USB Drive...
Make sure there is nothing attached to the laptop,remove all devices like keyboard,mouse, flash drives and retry. If still having same error flip the laptop over and remove the battery and open up the 2 other compartments that have a screw holding them. One holds the memory modules and the other the hard drive, check and re seat all connections, then try again. If you still have the same error your hard drive is most likely failing,
Thanks for using FixYa
I got a error code 10008 what do i need to do
Your hard drive has a problem. Contact Compaq for replacement if it is still under warranty.
My laptob gives me error code 10008 when i turn it on what could i do ?
Glad to HELP YOU!
Usually that error [code 10008] appears when the hard drive has a SERIOUS PROBLEM!...
If your laptop [by the way... it's LAPTOP and not "LAPTOB"...] is under the warranty conditions get your hard drive replaced. If not - then buy a new hard drive for your machine.
A good and reliable hard drive is under $100 these days.
Go on Google [or any other search engine ] and check for a HARD DRIVE DIAGNOSTIC UTILITY; I've found for you a few HERE.
Download it, install it and run a test. It might be not only the HDD with problems; it could be some other components of the motherboard that might generate a hard drive failure...
GOOD LUCK!
Erroor code 10008
According to Compaq tech support. That error code of 10008 indicates the hard drive has failed and should be replaced. I would recommend contacting HP/Compaq and finding out your warranty status. If it is still covered under warranty, they can replace the drive with a new one. You will need to contact them to find that out.
3helpful
Compaq Presario PC Notebook Error code 10008 hard disk 1
It means your hard drive has failed to boot, try reinstalling your operating system. If all else fails send it to the company.
Minolta 2200 service code 16
(TABP0902037EN00) - magicolor 2200 DeskLaser - What are the steps to fix a service call 16H transfer belt rotate error on a magicolor 2200 series? (TAUS0805552EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'ACC_Getstatusr EC;Code=__D, Resetting ACC to Initial State' (q0601101) (TAUS0805008EN00) - magicolor 2 + - Installing CrownNet code on the Crown monochrome printer (q0499042) (TAUS0803976EN00) - magicolor 2200 + - Flashing System Code to DeskLaser to Correct 'Starting System Firmware Image' Message (q0202107) (TAUS0806277EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Missing' (q0800700) (TAUS0806280EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Missing' (q0800703) (TAUS0806281EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Fuser Missing (q0800704) (TAUS0806282EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Missing' (q0800705) (TAUS0806283EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Low' (q0800706) (TAUS0806284EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Empty' (q0800707) (TAUS0806286EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Fuser Unit' (q0800709) (TAUS0806287EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Life Low' (q0800710) (TAUS0806288EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Transfer Belt' (q0800711) (TAUS0806289EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'OPC Drum Life Low' (q0800712) (TAUS0806290EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace OPC Drum' (q0800713) (TAUS0806292EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Waste Toner' (q0800715) (TAUS0806293EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Life Low' (q0800716) (TAUS0806294EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Oil Roller' (q0800717) (TAUS0806295EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Input Tray' (q0800719) (TAUS0806296EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Upper Bin' (q0800720)
1helpful
3answers
Asi gave mine laptop compaq c700 pc notebook to hp service centre for check up. they told me that there is a hard disk problem .so the problem was "HDD test fail & check with another HDD.& all...
Only Hp knows what that means in their diags. Get it shipped back and take it to a Locally owned PC shop and have them take a look at it. It is possible that you have just enough file fragmentation and file structure corruption that it is fail diags. Why did you take it in to be looked at anyways?
16helpful
4answers
Error message: Failed- Replace Hard Disk 1 (Warrany ID error code 10008) what does this mean I have a compaq Presario A900
It means that Hard Disk 1, which is either the first or second harddisk in the laptop, has failed. First open the BIOS on your latop. Before windows startup there should be a Compaq logo on screen. There also is some text saying which key to press to access BIOS. In BIOS, try opening some menus and look for a menu that shows your disk drive. In the same menu should be your harddisk. If it is there, go to A. If not, go to B. A: The disk is not broken, it just made a write error that destroyed WIndows. Insert the disk with your operating system on it into the laptop, and reinstall it. Your data is gone, but the laptop will work. If reinstalling the OS gives errors, and is unable to complete, go to B. B: Your harddisk is broken. There is no way to fix it, and you will need a new one. Contact Compaq if your warranty is still valid, and if not, take it to the nearest computer shop and ask for a new harddisk. If you have any more questions or trouble just post back here. I hope this helps, Yannick
Failed Replace hard disk 1 warranty id code 10008
As the error message states you need to replace the hard drive as the hard drive is most likely dead ie not working / broken.
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
