SOURCE: How can i put a password to my N router (DIR 615)?
Connect a LAN cable to the router and computer. Open your WEB Internet Explorer and your in the router's URL IP configuration address.
This will be 192.168.0.1 and the default Login = admin and the default password = (blank) just press Enter.
You can now change the default password.
SOURCE: Problem for D-Link DIR-615 Wireless Router, Orange Power Light
I have had multiple problems with these routers. They tend to drop signals or have other issues that are hard to explain in a few short sentences.
After you rebooted did you open your browser and type in the IP address to connect to the router software?
can you be more specific?
Testimonial: "There was a problem with router itself, after replacement everything works fine. Thank you for an advice"
SOURCE: Lost Installation CD Rom for D-Link DIR-615
Try going to the d-link.com web site, and see if you can download it from there.
Testimonial: "Thank you for all your help, HAPPY NEW YEAR!"
SOURCE: Hello, I forgot the Network security Key , how can
Ok. you cannot so much "Solve" it, as such, as you must simply re-set it up again. You must access the router via a browser, and login, now you simply set it all up again, OR leave as is, except for the "Key"and when you get to the security tab, to do the WEP?WAP key, when the "Key" this is generated, I copy paste into a notepad document, & save. When you setup the security. do it all save and exit. Now when you try to access the WiFi network, from a "Client" you will be asked for that key, simply copy paste it from the document.
Also ensure DHCP is set to OFF and disabled on ALL client computers.
START>>RUN>>services.msc enter, When services comes up, scroll down to DHCP and set to OFF & Disable. Reboot.
