Try to work through microsoft , can set up my email because the email and the startup are mixed up, can get into the laptop with the email password but the emails is blocked because it is the wrong password, therefor even microsoft can not email me a "code" to fix it up we tried several times
So this is a laptop, model name and brand; if it is out of warranty then you can open it up and see if next to the CMOS "battery" there are some jumpers, I would suggest to look up the motherboard manual on how to go about this, if you have never done this I suggest to have a professional do it for you, but before opening it make sure that this is possible on the motherboard.
good luck!
You can get the battery out/and reset the wholw system
SOURCE: Advent 7110 bios password hell
ftp://ftp.sabioproducts.com/pub/Notebook/EF6C/EF6C_Service_Manual
I believe this is the manual associated with this Advent laptop. Select "disassembly instructions". Item is a viewable PDF document.
SOURCE: remove password from award bios on asus laptop
Click on the link below and follow the instruction
http://www.fixya.com/support/r1257563-break_bios_password
SOURCE: How to reset bios password
The FSC 1320D's are truely remarkable... We haev had a default BIOS password for our laptops for a while now, but it has recently started to have been guessed or found out. So of course, they needed to be changed. And suprisingly enough, the FSC 1320D will not allow you to reset the BIOS password through ANY user method so far, and we really have tried everything.
Removing the BIOS battery - This does nothing, at the best of times the system will display an error saying it has been removed but other than that the BIOS password remains.
Updating the BIOS - Most people would suspect that if you update the BIOS it compeltely refreshes the set system settings, including the BIOS password. This again, is not the case with this model, as every attempt at updating the BIOS so far has been deemed useless.
BIOS Corruption - This again, does not work. It leaves the system in a dead state, usually the BIOS resets. This has occured once, as during boot we noticed the options to scan memory had changed and it took longer, but the BIOS password remained.
Backdoor Passwords - Again, do not work. We have tried the entire list submitted by Ekse.
Reset VIA Software - There are some hacking programs out there which reset the BIOS through the Operating System. And i think we can all guess what im about to say... They don't work. It may just be for this model, as i've not tried them on others, but the BIOS password for the FSC 1320D does not get reset using this applications.
So, the verdict?
Apparently you can submit your laptop back to Fujitsu Siemens for an 'Out of warranty repair', and they will reset it for you. Assumingly by changing the BIOS chip completely. The only downside to this is that it can cost anything from £50 - £150 depending on service charges and delivery costs. My opinion, wasting time on a laptop that is past its sell-by date like the FSC 1320D is really not something you want to be doing. Buy a new laptop and sell the 1320D for spare parts.
SOURCE: Locating the CMOS battery, DIP switch or Jumpers
THE CMOS BATTERY IS ON THE MOTHERBOARD,I HAD TO COMPLETELY TAKE APART MY LAPTOP..I LEFT IT OUT FOR 30 MINS ..PUT IT BACK TOGETHER BUT IT STILL ASKED FOR PASSWORD...TRYING AGAIN AND WILL LEAVE BATTERY OUT 24 HOURS.bE CAREFUL IF U TAKE IT APART AS IT IS NOT EASY.CONTACT ME IF YOU LIKE I'LL HELP IF I CAN. [email protected]
SOURCE: hp compaq nx8220 - Administrator password cannot be reset
If this issue started with a motherboard error that appeared to be a faulty CMOS battery and then it started incorrectly detecting your memory and now is asking for a password it could be a faulty motherboard. If you are 110% you or anyone else has set a password on that laptop then I would say your motherboard needs to be replaced. It is a difficult process to reset admin passwords on most laptops due to a security chip that will prevent the trick of removing the battery from working. In all honestly if no one has set a password and the motherboard THINKS someone has then even if you reset the password you will still have issues. There is a small chance your CPU or RAM could be defective. But, again going back to it saying you have a password set that was never set. It just yells faulty motherboard unless someone has set a password without you knowing.
The general categories of solutions to reset a BIOS password are:
