SOURCE: cannot boot up laptop acer aspire 1410 have
Don't worry it can be reformat. Your operating system is corrupted because it does not boot up. You need to reinstall your operating system and since you have external cdrom, you will use it to install your operating system. But be ready for your acer aspire 1410 driver based on your operating system . Here is the drivers if your don't have http://www.driverstock.com/Acer-Aspire-1410-driver-download/4-21-12835/index.html. And here is the my blog on how to reinstall operating system http://www.fixya.com/support/r7410371-reinstall_windows_xp_or_installing_clean Good Luck
SOURCE: I have acer aspire 5315
Hello.
If the drive does not open on its owm, you should be able to open it manually. The drive will have a smal hole in the fronto of it. If you take a straightned paper clip and insert into the hole the drive should open.
SOURCE: how do i get the
It depends on the drive model but there is usually a 'button' on the drive door: while the unit is power up, just press it to open the cd/dvd drive bay.
Hope it helps.
The CD/DVD drive may need reseating to make proper electrical connection. Remove this drive and insert it back into the laptop.
Next try cleanibg the drive.
The laser lens maybe dirty, use a CD/DVD lens cleaning kit to clean the lens int the drive.
If this does not fix your problem then the CD/DVD drive is faulty and needs to be replaced.
SOURCE: acer aspire 5738 cd DVD drive not working
1.start>control panel>all control panel items>AutoPlay
change settings for each desired media
2.update the drivers for the DVD drive. search in all programs for the program name, go online and download the most recent driver
3. you may have mulitple programs that controll DVD/CDR reading ability. this will sometimes confuse/conflict the drive. try removing one using add /remove programs from the control panel.
