LG LRFD22850 Bottom Freezer Refrigerator French Door Logo
A
Anonymous Posted on Dec 07, 2017
Why does my refrigerator short out when I open the left door?
When my LG French door refrigerator is running and I open the left door, it shorts out and trips my circuit breaker. So, I have to close the door and reset my circuit breaker and all is well. This does not happen when my refrigerator is not actively cooling/running. This refrigerator is just shy of being 2 years old.
Mark Smith
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 1 Answer
  • Posted on Nov 09, 2021
Mark Smith
Contributor
Level 1:
Welcome Back:
Answers
Questions
0
Helped
880
Points
Where is ground wire located on refrigerator
obsteiner
Level 3:
  • Master 901 Answers
  • Posted on Dec 07, 2017
obsteiner
Master
Level 3:
Answers
901
Questions
Helped
302755
Points
7223
Something in the left door is shorting to ground. The constant movement of the door has worn thru a wire/wire bundle and that wire is touching metal.
  • obsteiner Dec 07, 2017
    Depending on how the wiring is installed you may be able to see the problem if you look closely.
5 Related Answers
Anonymous
  • 958 Answers
  • Posted on Feb 13, 2008
SOURCE: lg french door fridge
do you have mechanical button switch that should close the light if you close the door?... they could be defective. try to look for these button switch that the doors presses as you close them. if they dont have, then they may be using a magnetic door switch which would be very hard to locate and trouble shoot.
Anonymous
  • 828 Answers
  • Posted on Jul 31, 2008
SOURCE: LG LRFC25750 Refrigerator French Door
Freezer section evaporator fan motor bearing are going out. This would be indicted by a high pitched squealing noise. Have the fan motor replaced and it should solve your problem.
Anonymous
  • 221 Answers
  • Posted on Jan 16, 2009
SOURCE: LG refrigerator french door icemaker not working
The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
The ice maker has completely stopped producing ice
The ice maker is producing ice poorly
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Anonymous
  • Posted on Apr 30, 2009
SOURCE: Roaring sound
I have had the same issues. I have owned my LFX25960 for 18 months. All the cooling, noise, and condensation problems are related to 2 fans. One for the freezer/refrigerator compartments and One for the Ice Maker. The fans, apparently, are not sufficient to move enough air through the coils located behind a plastic panel in the freezer compartment. The part numbers for my fans are 1. Ice Maker 4681JB1029E and Refrig/Freezer 4681JK1004E. It is not impossible, but fairly difficult to replace them yourself. You have to remove the large slide out freezer drawer and glides. Then work the back freezer panel loose from the bottom. Be careful not to break it. It is plastic.
Routine maintenance: Pull the refrig out from the wall and blow-out the coils and fan located on the lower right rear. You might find it easier to do this by removing the cover on the lower, back of the refrig.
Robin low
  • 28 Answers
  • Posted on May 09, 2009
SOURCE: Refrigerator Door not staying closed
Try to raise by adjust the 2 front footing slightly higher than the back, this will tilt the unit slightly backwards. That will help the door to close back by itself.
Since hours I hear 3 short beeps - no open door alarm., No error code.
This model has trouble with ice building up behind the freezer doors preventing them from closing all the way. You may need to defrost.
Why my alarm wont come on when door is left open
there is a short circuit in wiring. please check its wiring
I have a LG refrigerator w/french doors. We are trying to come up with a solution to slightly restrict how far the left door opens.
Add a stopper to hinge of door find the farthest you want door to open and add it to the pin just like they make for house doors
or strong braided cable attach to door bottom to center of bottom of ref size cable to how far you want door to open. a light spring can pull cable back to base of ref,
French door makes high pitched squeal when I open it
Lube will not help. The door needs adjustment. Look on top of the door where hinges are and try minor adjustment. You will need help to guide you.
1helpful
The LG refrigerator door lights do not come on when I open the door every thing else works. French doors #LFC25760SW Hepl!!!
Were the doors left open at anytime? If so it has a thermostat that will shut off the lights to keep from getting too hot, If they werent left open, could be bad bulb or stuck or bad light switch on the door, all very easy fixes.
Sean
Ice/water panel loses electricty when opened
That sounds like a wire is loose in the pin plug at top left hinge. The difficulty in opening the L door and the puff of air has me interested in what is happening. I will assist you if you like and will send a Service manual shortly. This may not be a simple solution or a one word solution but I will stick with you through out the repair, Thanks, Sea Breeze
1helpful
My lg refrigerator model GM-F228JTKA is displaying the message ER FF
The common service code ER FF is
Abnormal freezing
BLDC motor
Motor defect, hooked of lead wire
to fan, contact of structures with
fan, short or open of lead
wire(there is no signal of BLDC
motor more than 115 seconds in
operation of fan motor)
It appears you have a fan problem.
2helpful
Top LG Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
