SOURCE: fisher & paykel (mw511)
check out the DRAIN MOTOR PUMP , its a small motor with 2 hoses connected to it , it could be clogged , need to remove it , inspect inside the impellers for any debri , clean it , re install and try again , hope this helpful AJ
SOURCE: Our Fisher and Paykel Pride
Sounds like your pump is blocked. **UNPLUG the machine**. lift or drag the machine to a spot where you can let the water dump out. The water comes out fast and makes a big mess. Tilt the machine back. On the front-right underside of the machine you will see the pump with the fan hanging down. Unplug the white plug and the earth cable from the back of the pump. You might notice that there is a white plastic clip that you can move to the side. Hold the clip out and twist the pump clockwise. At this point the pump will drop out and water will go everywhere. Try and take the pump out kinda fast so that the coil does not get too wet while the water is dropping out. you might find a blockage (coil, hair clip, underwire etc) sticking out from where the pump impeller sits. Pull out your blockage and check that the pump spins freely when you spin it by hand. If it does not spin freely you need a new pump.
Now, after you unblock your pump, you can put it back together the same way you took it off. Make sure the white plug is not wet before plugging it into the pump and make sure the pump coil is dry too! use a blowdryer to dry for a minute if unsure. When twisting the pump back in, the wires should be at the back of the machine and the earth cable is kinda close to the rotor (motor). Make sure the pump is sitting flat so the seal works too. That clip should click lock back into place to hold the pump from turning. The washer will not spin until all the water is out in case you are wondering. Hope this helps!
SOURCE: Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
SOURCE: Fisher and Paykel GW612 - Lights showing
Hi just read your posting.The fault on your machine is called Single Rotor Position Sensor Error.The rotor sensor is attached to your motor which is located underneath the machine.Now the Error Code will come up on your machine because 1--The wiring to the Rotor Sensor is faulty. 2-- The rotor sensor itself is faulty or 3--- The motor controller, 'which is located under the top panel is faulty.Unfortunately to test the rotor sensor you need an RPS tester .This device will also check the wiring to the rotor sensor.If you have an electrical test meter I can guide you throe the testing of the wires to the rotor sensor but without the RPS tester you cant accurately test the rotor sensor.Some service techs I know just change the rotor sensor to see if that rectifies the fault but in your case you dont have a rotor sensor so even if you do purchase one and change it, the fault could be your Motor Controller.My best advice to you would be to borrow an electrical test meter if you do not have one and reply back and I can help you eliminate the Wiring as the cause of the fault,and then contact a service tech to find out if the fault is with the Rotor Sensor or the Motor Controller.But if the fault is with the wiring then I can guide you throe step by step to repair it.I hope this helps and please reply on how you got on or if you need further assistance.Good luck.
