Sony DCR-TRV285E Digital-8 Digital Camcorder Logo
p
pawan Posted on May 07, 2014
My camcorde showing cassette is locked - Sony DCR-TRV285E Digital-8 Digital Camcorder
JVC Camcorder GR-AX2 error code E04?
The error code E04 on a JVC Camcorder GR-AX2 indicates a problem with the cassette mechanism. This could be caused by a number of issues, such as a jammed cassette, a malfunctioning cassette compartment, or a problem with the camcorder's loading mechanism. In order to fix the issue, the camcorder may need to be serviced by a professional. In the meantime, you can try removing the cassette and reinserting it to see if that resolves the problem.
good luck
How do I fix the tape holder system on my camcorder? The door won't lock, and the cassette won't get inside the compartment.
hi,
is it close without a cassette ? if so the reel sensor in the cassette compartment may be faulty. if the head drum not rotates the cassette drive will not work correctly, if so please loosen the head drum with a plastic rod or some tools like that. do not put your finger in hence sometimes will jam your finger. remember don"t touch the scanning chip of the head.
3helpful
Reinsert Cassette Error
Hi, I had the same problem. When I inserted the new (or old ) cassette, it was showing me the same simbol as you are describing here.... The one thing to do here is to let it check in some CamcorderReparingCentre. After I let it to repare it they told me that there was some kind of engine broken , I paid £60 for reparing but my camcorder is working again,properly like before...
1helpful
2answers
How to remove cassette case in sony camcorder dcr-hc26
i spraaid it from outside and it is working good at this time
but i still want to have removing instruction or any schmatic diagram of mecanical parts like cassette case to helpe me for removing it if it happend to show error ( reinsert cassette)
thank you
"DEW"
Dew has condensed in the camera. Eject the cassette but leave the cassette door open.remove the battery . Borrow a hair drier . set it to optimum temperature(not vey hot but but hot enough to cause discomfort when blown on fingers). direct the hot air through the cassette compartment door for about five minutes. reattach the battery and reinsert the tape.
Good Luck,
Luwangula
1helpful
E04 Error Message
Here's what i found. I was able to clear the message by opening and closing and ejecting the cassette. I also had to play with the battery at the same time. Keeping the cassette door open and then pulling out the battery. After is did this a couple of times i got the message to clear. I too haven't used my camcorder for some time and now that the error message has cleared the camcorder tells me that i need to clean the heads. Hope this helps. Below is the message i found that pointed me toward ejecting the cassette. Good Luck, i'm off to buy a tape head cleaning cassette. An error indication (E03 or E04) appears. - (E03 or E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a malfunction of some kind has occurred. In this case the camcorder's functions become unusable. - Eject the cassette once and re-insert it, then check if the indication clears. When it does, you can resume using the camcorder. If the indication remains, consult your nearest JVC dealer or service center
Cassette will not load!
I have one doing the same thing. I called Cannon and the told me I would have to send it in for service. Now after reading that about 10 other folks having the same issue, I think Cannon has some issue with the ZR100.
Machine just shut off when opening the cassette door. Locked up!!
look for a tiny pinhole and insert a pin while powered up to reset the device
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
