SOURCE: help, my camera wont take pictures
I just had this same problem, slightly panicked. But thanks to the internet the answer was fast and easy. :) Hold down the shutter button and then advance the film lever. also the film advance lever should be facing you, as if trying to poke you when you lean in. Then take a picture. Practice this with no film inserted. Worked for me. Hold down the snap button while turning the advance film lever.
SOURCE: Isn't recognizing there is film
I will offer a solution under the assumption, that you are not familiar with this camera. Please ensure the film is loaded correctly extending the film all the way across to the orange line located on the right side near the winding post. This ensures the film is positioned correctly and will feed onto the post. Also the film advancer may need to activated by releasing the shutter. Hope it helps. Good Luck!
SOURCE: Nikon N65 Film Camera Broken latch
You have to replace the whole door. There is one on eBay, but you won't like the price. Find it here: eBay
SOURCE: Nikon FE- Winder return position
YES, THE PROBABLE CAUSE IS THAT AFTER 25 YEARS OF USE YOUR POOR NIKON PROBABLY JUST NEEDS A GOOD CLEANING! I DON'T THINK IT IS ANYTHING A GOOD CLEANING CAN'T CURE. I HAVE INCLUDED A COUPLE OF SHOPS THAT REPAIR NIKONS AND GIVE FREE ESTIMATES. WHILE I DON'T ENDORSE ANY REPAIR SHOP PERSONNALLY, I PASS THESE ALONG FOR YOUR INFORMATION. I HOPE THIS HELPS. I REALLY BELIEVE THIS WILL TAKE CARE OF YOUR PROBLEMS. ALSO, BY THE WAY, I ALSO HAVE A NIKON FE AND IT'S A GREAT CAMERA. ENJOY!
www.keh.com
www.camerarepair.com/camera/repairs/264-NIKON-FE
THESE ARE HOTLINKS AND WILL TAKE YOU TO THE PAGE.
SOURCE: What kind of film do you use with a Nikon N65?
You can use any good 35 mm film. If you need advice on best film to use take your camera and your lenses to a camera store and the techie will assist u
