Emerson 32" LCD TV will not turn on Model LC320EM8A
I turn the power on and the green "Power On" Light flashes 3 times and turns off. I never see a picture, the telivision will not stay on? Any help? Thank You
It sounds that the main digital board has damaged. 12 blinks indicates it. if you wish to know more check this link for more details about 12 blinks to Emerson TVs
Sounds like capacitor/s failing on the power board. This is a common issue and there is lots of literature and even videos on how to perform the repair on web. A shop will charge upwards of $200 for this repair yet if you find the components and only have them change those; perhaps they will work with you on cost. GL!
Hello, The flashing power light indicates a failure in the power supply board of your tv. We should be able to repair the board for our standard rate of $45 plus return shipping. If you are interested in setting up a repair please use the following link to our web site: http://www.ccl-la.com/blog/index.php/service-request-form/ Our normal repair turn around time is 2-3 days.
The most common problem is the Power/Backlight Inverter Board. There are 6 mini transformers on the board, one goes bad and the TV will turn itself OFF automatically for " Protection Mode". Replace the whole board or replace the bad mini transformer.
Part number#
Whole board, BA71F0F01042
Mini Transformer, LTZ2PC0MS008
Power supply board is dead,if green light on keep blinkings,notthing come on.Power green light is solid,nothing come on.Than ur Tuner signal board is dead.
this is 9 times out of ten a bad relay or power supply unit there might be a bad capcitor inside that is causing this shutdown, I would rule out the powersupply before the relay at this point. Good luck when i doubt please bring it in for repair its still a good tv to invest in.
i turned on my tv and it blinks green continuesly. it wont turn off to red light. i unpluged it for 30 min. repluged it and green light comes on and wont stop blinking
