Philips Magnavox 9P6034C 60" Rear Projection Television Logo
Posted on May 06, 2014
Program a charter cable remote to old sanyo tv
1 Related Answer
Puppet03
Puppet03
  • 172 Answers
  • Posted on Oct 24, 2009
SOURCE: need program advice for philips direct tv 2585/01 remote
http://www.directv.com/learn/pdf/System_Manuals/Philips/Philips_DSX-5150_5353_5375.pdf
only one i found but they all seem to work the same.
Testimonial: "Thanks!!! I received a response within a matter of minutes and resolved the problem. "
Have a RCA 55" flat screen, with Spectrum (Charter) Cable. Can't get the charter remote to turn tv on and off. Everything else works fine. What's problem?
Hey there,
Contact Charter customer support and have them walk you through “programming” you’re remote to the television. This will alleviate your problem.
How do I program a charter remote to a rca converter box
Charter 1060BC2 and 1062BC3 - Setup
www.urcsupport.com/html.php?page_id=762
SETUP. The Charter 1060BC2 and 1060BC03 Remote Controls are preprogrammed to operate the cable box (converter) provided by your cable system, an RCA TV, a Toshiba DVD player, and a Pioneer audio receiver. To control devices other than the default brands, perform the following steps; otherwise skip this section.
Program the Digital Cable Remote Control
mscharter.custhelp.com/app/.../program-the-digital-cable-remote-control
Dec 10, 2013 - Highlight or write down the codes and device you wish to programbefore moving on to Step 2. On the remote control, press a device key once (i.e., AUX, DVD , AUD, TV or CBL); it will blink once. Then, press and hold SETUP until the selected mode key blinks twice, then release SETUP.
Charter.net Charter Remote Controls - 1060BC2/1060BC3
www.charter.net/.../charter-remote-controls-106...
Charter CommunicationsProgramming Codes: Select the manufacturer of your device from the list. The codes will appear beside the list boxes. Not all manufacturer brands listed may be ...
Charter.net Charter Remote Controls - OCAP-4
Charter cable remote code
Lacking way to much information I presume you are typing about a universal remote control I might be out of my mind here but I am not a mind reader who made your universal remote control?
Terry
How to program remote
is there a menu button?
sometimes the setup is buried under another button so I would call the cable company and ask.
there is a remote code for your model tv that has to be input.
My Vizio Bluetooth remote with keyboard has stopped working. I have spoken with Vizio tech supp. to no avail. I have a remote I used with my old TV issued by Charter because I have Charter cable. I want...
you need to contact charter for support on their remote and how to reprogram it for your new tv. for most universal remotes there is setup key or you have use a key combo to press to enter into setup mode and a user's for the cable box may have this info. however, if you do not have or did not get a user's guide then you need to contact your charter cable company for the info needed to get the 2 devices working together. refer to cable co. tech support.
1helpful
Charter remote will not change channels--I have put in tv code but still nothing--noting on the remote will work except to power the tv on
You will need to program it to your cable box to change channels. Remember, the channels in your tv are coming from your box, so if the remote can't control the box, you won't be able to change channels. Call charter for help on programming remote to cable box.
9helpful
2answers
Just received a new moxi remote because i was having trouble with my old one. My moxi box is a silver motorola box that says broadband media center. my old remote says charter digital on the bottom and...
Do you know what model MOXI box you have? The new remotes weren't programmed to the MOXI 3012 box. If you have the Moxi MP12, BMC9012, BMC 9012F, BMC 9022 you will need to program the remote to the box.
1. Turn on the Moxi STB.
2. Press and hold the MOXI and OK buttons on the remote until the red LED at the top of the remote blinks twice.
3. After the red LED has blinked twice, release both buttons.
4. Using the numeric buttons on the remote, slowly enter 0, 0, 4. The correct entry of this code will cause the red LED to blink twice.
5. The remote is now programmed to operate the Moxi STB listed above. Go to “Programming the TV”.
I need the codes for a GE Universal remote for my
HERE IS A WEBSITE THAT SHOULD HAVE THE CODES YOU NEED.
http://www.xdiv.com/remotes/
IF THIS HELPS CAN YOU PLEASE GIVE ME FEED BACK?
( I GUESS IT IS IMPORTANT FOR THIS SITE)
1helpful
2answers
Can you switch from tv to video input on sanyo ds31520 tv without a remote
no you require the remote or a universal remote or sometimes a cable remote that has been programmed to work the volume on the tv set will have an input button .
111helpful
5answers
Need Philips Universal Remote Codes for a Sanyo TV
Hi Pamr
Try the Phillips website >HERE< which links to their Universal Remote support centre. Unfortunately you haven't given the details of your actual remote but you should be able to find it and download a manual or email them direct.
Sanyo TVs use all these codes:
0506, 0311, 0612, 0002,
0428, 0802, 0412, 0619,
0208, 0157, 0292, 0036,
0011, 0370, 0072, 0216,
0217, 0104, 0045, 0009,
0163, 0037,
Sorry there are so many, but one should work.
Best wishes...
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
