Stopped working. Have reset on/off turn table switch to no avail.
I'd check to see if the turntable motor has continuity. If it does, check to see if 120 volts is being supplied to it. If both are o.k., then the motor has probably bound-up in some way internally. There's also the possibility that it has mechanically become detached from the hub that turns the glass tray.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
CHECK TURN TABLE MOTOR
Dave: thanks. I checked power to the motor and it was good. Ordered a new motor and it is now working like new,
