SOURCE: AM-14 rinse cycle water useage
The psi should be in the green on the gauge,20-25.The 10 second rinse cycle is the default setting.
SOURCE: AM14 tank heaters--when are they energized?
How hot is the wash temp?It should be 150-165 degrees.The model is an am14 not an am15?I'm hobart tech and repair these units weekly.Let ne know.
SOURCE: hobart lx18 no power to detergent pump, during the
you have to go into program and activate the detergent pump.sounds like somebody deativated the det. program
SOURCE: Wash Temp will not get above 140
It depends on the design & the programming. By chance if the thermostat is faulty this can happen. However refer user manual and consult the service provider or the manufacturer!
