RCA F27450 27" TV Logo
A
Anonymous Posted on May 06, 2014
What do i do when i plug tv in it blows trip switch?
3answers
I have a Sony xr65a80j tv that will immediately trip a circuit breaker when I try to plug it in.
you have a short in the unit need a meter to test and check or send out for repair
3answers
Hi my samsung fridge/freezer suddenly started to trip my electricity,I changed the plug but still is tripping the electricity,also checked the socket,definitly the fridge
First you must isolate the problem. remove the rear service cover(unit unplugged) disconnect the wire plug to the compressor. replug the fridge. If the circuit doesn't trip ,then the compressor or relay is defective.
2answers
Convection electric heater by " de long hi" Heater does not turn on when pres the "power on" switch
fuse in plug often blows. but delhonghi are weird. i've got one that trips unless i put an rcd plug between it and the wall socket to stop it tripping. is yours tripping off straight away or just not coming on at all? listen for a cvlick as soon as u switch on. try another wall socket. check fuse
Lights went out breaker was thrower switched breaker to on several times when I came in tv would not come on electricity is good to it so is their a fuse and where is it on tv or is there a nother place on...
Pull the TV plug out of the electrical outlet. In fact, pull all plugs from all nearby receptacles. Try the circuit breaker. If it still trips, pull more plugs from the receptacles untill the circuit breaker no longer trips. Reverse the process to isolate the plug that is causing the circuit breaker to trip. Repair broken item.
Tv when plugged in trips main fuse box
If there is a short circuit inside the TV, the fuse should normally blow first before tripping your breaker. The only exception is if you have a short in the ac cord or the line filter of the TV set. Have you tried the tv on another circuit to see if it trips that breaker? If not, it could be that your first circuit is close to an overload and the TV is simply pushing the circuit "over the edge".
Pushing the power switch does not turn on the vacuum.
The only fuse is in the plug if this blow then it might trip the CB out
Tv trips circuit breaker
it will be one of these on the power board these will blow if they get over loaded and short out the power line in turn tripping the electric.
su-logo-bridge-rectifiers-402fdf5ej2eemw1gcpqyfpcr-2-0.jpg this will be on the mains side of the power board. can be one of these types in the photo. but it can also men something else has blown on the 5 volt side of the board.
3answers
Goodmans 27 inch LCD
Sounds like the power surge may have blown the fuse in the TV. You can replace the fuse and see if that works. If not, more damage to the power supply unit may have occurred.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
