SOURCE: 8360 new holland tractor tansmission oil pressure
havent worked on one but if oil pressure light is showing on the gearbox then something is wrong ,either oil is low or the pump has packed up or the pick up pipe filter is blocked .either way what i do know is that seperating the units is a big job requiring specialist equipment which no doubt you know already,
SOURCE: new holland tractor won't start just clicks
check both batt. termial ends,also check cenections at the starter and the ground wire,if that wont fix it next maybe charge batt .
SOURCE: Tractor
video will not play but from the symbol in the video i would hazard a guess and say its the rear diff lock
