Installation diagram needed for carburetor linkage installation
SOURCE: chain saw
Hi
Look at the bottom of the chainsaw.There is a screw(it has connection with the oiler piston).
best regards savumihai71
SOURCE: I am installing a throttle pusher and choke arm in
Try downloadinf the IPL here:
http://www.husqvarna.com/us/homeowner/support/download-manuals/
I should help.
Lou
SOURCE: husqvarna chain saw rancher 55
Try this get back to us with the results.
Ignition Coil Test
http://www.youtube.com/watch?v=L7WNBDRG4C4&feature=PlayList&p=3789DC1EE87C8098&playnext=1&playnext_from=PL&index=21
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You don’t have to bend up the electrode. HTH
Lou
SOURCE: what is the fuel mix
33:1.............always mix it on the heavy side and you will never burn your saw up.........go to walfart and get a bottle of "gumout" octane booster and stick it in the gas and it will run better than ever.......
SOURCE: I have a Rancher 55 18" with a new chain. Started
First thing you need to check is the cylinder.Take the spark plug ouy.use a flashlight and look down the hole towards the muffler side.If its scratched up afraid the motor is shot and will need to be rebuilt.If its not scratched up let me know on here.Then I will give you more things to check.
