Hi
I downloaded IE8, after downlading the toolbar (file, edit etc) was not there. I then restored my computed to before the IE8 download thinking it would go back to normal, however now when i click on my desktop IE logo it goes to open but immediatly closes again!
I know my internet is working as I can log onto MSN messenger and also I can open the internet through MSN Explorer. I tried downloading IE8 through my MSN Explorer, however when it brings up the download box its blank.
I cant get any further! - I tried to restore back to after I downloaded IE8 but my computer said i need more memory - so i ran disk clean up, when I went back to resotre - there was no previous restore points there any longer!
Is there anything I can do?? - Can I download IE onto a disk on another computer and upload??
HELP!! - its my brothers computer, hes away on holiday and back on friday - I need to fix it before then!
Thanks in advance!
Its not a big problem dear ,you can uninstall the ie8 from add or remove programmes in control panel.
Goto control panel ,open add or remove programmes,find out the ie8 ,select and remove it from there.If you unable to find the ie 8 in the list or if therewill be no remove option there then tru wo remove windows service pack3 from the same list.
Best of luck
Please reply if the problem will be solved.
I will be waiting for your reply and votes.
Regard's ,
Ricky
Hi thanks for your help
But i cant resolve the problem - I checked and although I downloaded IE8, im actually still using IE7, the files for IE8 are installed on my C drive still. - I tried removing IE7 from add or remove programs area, however the remove option was not there, so i uninstalled Service pack 3, then it allowed me to remove IE7. After I removed IE7, I had no internet connection at all, (I thought it may have reverted to IE6 as default). I have restored my computer to undo my IE7 Removal so that I can access via MSN explorer, temporarily.
Can you advise what I should do next? I tried downloading IE8 again, but the download page opens blank.
Thanks again for your help!!
P.S also my Internet Explorer Icon On the task bar now says "Internet Explorer (No Add Ons)" and also that in my control panel the "Internet Options" section has dissappeared!
problem is now solved
thanks for your help though
:o)
