Drywall Logo
A
Anonymous Posted on May 05, 2014
Paint bubbles on drywall
I have some paint bubbles after painting over a drywall patch. Will these go away as the paint dries?
Ron Morton
Level 1:
New Friend:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Feb 13, 2015
Ron Morton
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
13
Questions
0
Helped
15217
Points
14
It's been almost 10 months since the question was posted so how does it look? Most bubbles appear under the drywall tape or could be from primer / paint being rolled over drywall dust. Tape bubbles don't go away. These need repaired by cutting out the bubbled tape and filling in with compound. Tape bubbles can be avoided by using a TapeBuddy taping tool. This tool applies compound directly to the tape so there are no dry spots under the tape. Hope this helps.
2 Related Answers
Anonymous
  • 217 Answers
  • Posted on Mar 10, 2013
SOURCE: Drywall needs to be painted
scrape a sample of the brown that you want to match, go to home depot and give them the color and they will make you a can that matches. then paint the drywall... i think that is what you were asking???
badboyz4life1989
  • Posted on Jul 28, 2014
If you have tape and joined the plaster board then get your paint you will need to miscoat first let it dry any imperfections will then Show a bit better use some poly filler sand when. Dry give second coat let dry then final coat and should look as good as a professional job if you arnt very experience d use matt emulsion as is easiest to paint with
How do I remove dried-on Fusion mineral paint from a latex drywall-painted surface?
Fusionā„¢ is a 100% acrylic, water-based paint. The "mineral" in Fusionā„¢ Mineral Paint refers to the pigments used which are harvested from the earth. ... Once cured, a surface painted with Fusionā„¢ is both water and stain proof. No primer or top coat is required, making it more of a one-step kind of paint.
I would put 2 coats of zinnser primmer over offending areas and then repaint to match.
tip
Patching a hole in drywall/sheetrock
The best way to patch a hole when you don't have backing material is as follows:
Step 1: Cut the hole out square with a keyhole saw or utility knife:
www.all-wall.com/s.nl/sc.11/.f?search=keyhole+saw
Step 2: Cut a piece of drywall, (the same thickness as the wall that you are working on), to fit fairly tightly into square hole. (HINT: You don't want the patch to fit so tight that it breaks the corners when you try to put it in.) If done properly, this patch will not want to stay in the hole by itself. You must leave 1/32nd of an inch all the way around the patch. Once the patch has been properly fitted, you are now ready to start taping it in.
Step 3: Put the patch face down on the floor or table so that you can easily work on it. Using drywall mud/compound & the 5" knife, lightly mud the back side of the patch (www.all-wall.com/Categories/Joint-Knives/Hyde-Stainless-Hammer-Head). Place a piece of drywall tape over the patch, allowing it to hang over the edge of the patch about 1 1/2" on the top/bottom of the patch (paper tape flaps).(www.tooldistrict.com/2inx500ftpaperjointtapepn500bypermaglas-mesh.aspx) Holding the tape firmly against the patch, wipe down the tape with the 5" knife.
Step 4: Once the piece of tape is wiped down, you are now ready to apply mud to the section of wall where the paper tape flaps will be laying. Place the patch over the hole, tapping it into place until the patch is laying flat on the wall. Holding your fingers on the seams of the patch, wipe down the first paper flap, and then the other. (HINT: Always wipe down the top flap first, then the bottom flap. Make sure the patch is flush with the wall, or recessed slightly. If the patch is sticking out from the wall even a little bit, it will be very difficult to hide!)
Step 5: Now that the patch is in, mud the horizontal seams in, paper tape, and wipe down. Repeat the process for the vertical seams. (NOTE: You may use mesh tape on these seams if you wish because mesh is a little thinner than the paper tape; making it a little easier to cover on the next two coats. Don't make a special purchase if you don't already have some laying around, it's not worth it. ( www.all-wall.com/Categories/Fiberglass-Mesh-Drywall-Tape/Thin-Drywall-Mesh-Tape )Let this dry for 12 hours before coating again.
Step 6: For the next coat you will need a 10 " broad knife (www.all-wall.com/Categories/Taping-Knives-Stainless-Steel/Hyde-Maxxgrip-Extruded-Back) Apply mud to the patch, covering the tape from the previous application.You will need to leave more mud around the outside of the patch; not too much on top of the tape. It is already going to be a little high on top of the tape so you are basically creating an optical illusion by building up around the patch. Let this coat dry 24 hours.
Step 7: If the 2nd coat was done properly, then putting a finish coat, (3rd and final coat), won't be a problem. This coat is just to fill in any low spots that you weren't able to get completely full the last coat. And if you did get it full the last time, congrats, then it is just a skim coat to fill in any air bubbles that may exist. (NOTE: Whenever patching over an already painted wall, the drywall mud/compound will bubble. This is normal. After 2nd coat of mud drys, scrape off the air bubbles before applying the next coat.) Let this coat dry for 12-24 hours
Step 8: Now the fun part begins: Use a sanding sponge or a sanding pole to sand the patch off, (http://www.all-wall.com/acatalog/A000_Dustless_Sanding_20.php). Then it is ready for paint!!
Good Luck!
If you should have any questions about"Drywall Finishing/Patching", or know someone who does, put your questions to Category:"Tools- Building & Power-HAND TOOLS" at FixYa.com
I will do my best to answer your questions about drywall finishing, but as you can see, just a simple patch is very involved. However, it would be best if we could speak on the PHONE or do a live CHAT. I can answer any question you have if it involves getting a wall ready for paint!
Jim
Key Words: Drywall/Sheetrock/Gypsum Wallboard, Patching, Texturing, Speckling, & Paper Tape
on Dec 01, 2009 • Hand Tools
3helpful
4answers
We found that the water was leaking into first floor ceiling from the pipeS of the toilet leading to bathroom wall. Plumber replaced the pipe and we don't see any leaks.
you need to leave if for a few weeks to dry out. or put a heater in room to help dry the dsmp patch, air flow heater. one with a fan.
May 02, 2018 • Home
Using fusion sterling paint after few day got lots of tiny bubbles. Done tv unitand vedside unit she and after few days bubbles. Any ideas.
Did you do anything to prep the furniture before you painted it? Bubbles usually form because there was something on the painted surface that is giving off gas of some sort, possibly through some chemical reaction to something in the paint. Did you use a chemical to clean it or maybe didn't clean the painted surface before you painted it? It is possible that if you used a cleaner and didn't get the cleaner off the furniture before you painted it this is causing the bubbling. Either that or there was something on the surface that you didn't clean off before you painted it. The only way to get the bubbles out is to sand them out. Use a power sander with a fine sand paper and make sure you wipe the surface down with a wet cloth and let it dry before you paint it again.
Jul 19, 2017 • Games
2answers
Paint bubbling and peeling soon after painting a newly rendered wall........how do we fix it?
Sorry for the paint peeling and bubbles. It's not the drywall tape that has bubbles... right? Paint can react like this when it is applied over a sanded wall that has not been cleaned and still has a layer of drywall dust on it. When primer is applied to the wall, it is best to use something to push the paint on the surface to combine the dust with the paint. This could be done using a paint pad but should be more than just rolled on. The paint needs to mix with the dust and stir it in with the paint so the paint get under the dust. You might try thinning the paint a little to allow for better attraction to the wall. So now how do you repair this? By scraping the loose paint off and starting with a new coat. You know. it could also just be bad paint.
Aug 02, 2014 • Drywall
My 2012 wall air condioner is leaking. How do I fix this and repair the drywall?
It sounds like the drain line is plugged where it goes outdoors, so water is backing up inside the unit until it spills over indoors. Clear the drain line.
You may need to cut a section out of the drywall where it's been damaged, then get a matching piece of new drywall to replace it. If you can cut down the centers of two studs, all the better - then you can screw the new patch directly to the studs on both sides. If not... at least leave yourself a couple of inches of drywall to stitch to - you can do that by screwing small pieces of plywood to the existing drywall, overlapping the hole. Then you can screw the new drywall patch to the plywood.
Next is your adventure in taping & mudding & sanding the drywall to finish the patch. Last, paint it to match the rest of the wall... or repaint all of that wall, including the patch. No need to paint adjacent walls, if your color matching is pretty close.
1helpful
Paint bubble over drywall patch
NO...Cut out the bubble, respackle, then paint.
2answers
Mar 10, 2013 • Drywall
I painted my ceiling and it started bubbling all ova i scraped this and now no paint on it iv tried to paint it now and its patchy i ccan describe it as looking greasy patches what shall i do
The weather must be fine its not cold or rainy when painting something. If your painting your ceiling and the weather is not fine try to open your heater to normalize the room temperature and allow the paint to dry as fast as possible.
Nov 17, 2010 • Dryers
Top Drywall Experts
RAJA NADEEM AKHTER
RAJA NADEEM AKHTER
NOEL
NOEL
Are you a Drywall Expert? Answer questions, earn points and help others
