Try the following and see if it will turn on... 1. First make sure the device has been charged. 2. Unplug your charger cord. 3. Remove the battery. 4. Press and hold the "Power" button for 30 seconds and see if the device will turn on. 5. If it does, great, if not yet, no big deal. Now plug back in the power/charger cord. (If it didn't turn on without the cord in, it should turn on once you it is in. Yes sometimes they will turn on, or try to turn on, even with nothing attached/plugged in.) 6. Now put the battery back in. If this doesn't help, then test the power cord to see if it is good. Either try your cord in another device, or try another devices cord in your laptop. Should that not be the problem, then check the battery to see if it needs replacing.
Put ur operating system again
SOURCE: My Samsung R530 Laptop`s screen
first cut the power of ur laptop and ,disconnect the battery ,
again connect battery and connect adptor and power on u laptop
if problem is not solve,
connect crt/tft monitor through vga port,
if laptop give display , then chk ur function of laptop with fn button.
Testimonial: "It worked! Tx."
