Volume drops then goes off turn volume control again and volume comes back then goes again
SOURCE: Amplifier cutting out when volume is increased
yea my friend your audio ic or transistor is either getting faulty or you have lose connection have a tech look at your set and make the nessecary repairs.good luck
SOURCE: Integrated Amplifier - Volume Control Problem
Hi there, get down to your local electronics supplier and buy a tin of spray switch cleaner. Try and spray some into th v/control and do the other controls at ther same time, this should solve the problem
SOURCE: arcam alpha 7 amplifier goes back into standby when volume is turned up
Can you, or can someone you know, check for DC voltage on the speaker terminals when the amp is on, but not playing? Ideally, the meter should read 0mV with no signal, and certainly less than +/- 10mV. Anything over +/- 30mV is worth having checked out, especially if it changes as you turn the volume knob with no signal applied.
SOURCE: Kenwood stereowith A-58 Amplifier, no manuals, so can't set up
mine does the same and it cost 100 pounds to have the output chips replaced
SOURCE: Kenwood stereo control amplifier KC-206 doesn't work
I found this thread when I was having the same problem with mine. Turns out that it's sort of a problem, but not really. Looking at the manual (which I found in another google search) I believe a "4" on the volume level corresponds to a default remote control setting. The remote varies the level between 0 and 10, but the "10" corresponds to the maximum volume setting on the preamp. So it actually works, it's just that the "4" reading doesn't change. There's probably a pin you can short somewhere to make that default to "10" which would be ideal. But I'm not sure where that is. Now on to my other problem. This particular preamp has a subtle 120 Hz hum...
