Hi Anonymous,
My name is Pradeep and I work for Dell's Social Media Team.
Please follow the steps on this link: http://lt.dell.com/lt/lt.aspx?CID=285905&LID=5550698&DGC=SM&DGSeg=DHS&RED=301&DURL=http://en.community.dell.com/support-forums/desktop/f/3514/t/19435878 and let us know the status.
Pradeep Lokesh
Social Media and Community Professional
Order Status: http://del.ly/61822hij
Download Drivers: http://del.ly/61832hid
Try Re-seating the RAM. This mostly does the trick.... does it beep any error sounds?
SOURCE: dell dimension 8100 diagnostic lights
Green Green Green amber is a start of "POV" whatever this stands for. Dells description is "System activity subsequent to video initalization" I would start with video card replacement,
SOURCE: Computer turns on but won't boot at all.
check ur PSu (smps) or ur mobo ic is get damaged u need to service it
SOURCE: dell xps 420 computer will
If the power light is blinking amber, the computer is receiving electrical power, but an internal power problem might exist.
Ensure that the voltage selection switch is set to match the AC power at your location, if applicable.
Ensure that the processor power cable is securely connected to the system board.
This can be caused bya defective power supply or a defective motherboard. Just to make sure thatnothing else is causing the problem, remove any PCI cards like modem, videocard, sound card, etc... Remove the memory modules and disconnect cables toCD/DVD drives. Look at the USB ports to see if any are damaged.
SOURCE: dell precision 670 won't boot
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty
http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
Testing & replacing the PC's power supply
http://www.youtube.com/watch?v=hbNxhvm0czs
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd and floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
Check your RAM.
The RAM is located in the middle of the motherboard.
There are tabs that you can push to release the RAM.
Remove it and put it back in place until the tabs pop out.
Loose RAM can cause your computer not to start properly where you want to see a video signal.
Remove the memory modules from their slots.
Take the opportunity to clean the slots on the motherboards and the memory module connectors.
Use compressed air to blow dust away and clean contacts with a soft cloth.
Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components.
Do not use solvent that may attract dust and never poke things like cotton buds in to slots.
lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r
Allow the pins to dry.
They will air dry in a matter of minutes.
When
you plug in the power cord is there any lights whatsoever on the computer?
When you press the power button do you hear fans running, hard drive spinning,
lights on the computer, hear any beeps or lights constantly blinking, hear the
DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a
second or two? If so the laptop is trying to boot or may have booted, but
the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the computer
and why it is not booting. Most times it's a motherboard issue when you
hear beeps or blinking lights continuous. Most times the problem is with
the memory or Video Card. Count the Blinking Lights or Beeps and take note of
their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoever
when you press the power button.
Maybe
you have a Static Charge Buildup. Remove the Power Cord, then Press and
Hold the power button for 30 seconds. After 30 seconds plug the power
cord back in and hit the power button to see if it boots.
Maybe
your memory is bad or the memory slot is bad.
Remove
the Power Cord, Open the Case and remove one of the memory chips. Set the
chip aside then try rebooting the computer. If it boots, then you know
the memory chip you set aside is bad so mark an x on it with an ink pen.
If it fails to boot then move the chip to the next memory slot and try
rebooting. If it fails take the chip out and set it aside, then put the
other chip in and try booting it in both slots. If it boots, just to
verify that the chip set aside is bad, mark an x on it and put it into the open
memory chip slot and try booting.
Maybe
your power supply is bad. Sometimes there is enough power to make the
power light or some other lights come on but not enough power to make the fan
turn on or hard drive spin.
Below are links and info I found from Dell's Website based on your model.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/specs.htm
Controls and Lights
Front of computer:
Power button - push button
Power light
green light - Blinking green in sleep state; solid green for power-on state.
amber light - Blinking amber indicates a problem with the power
supply inside the computer. If the system cannot boot and there is a
solid amber light, this indicates a problem with the system board (see
"Power Problems" in your Owner's Manual).
Diagnostic lights
four lights on the front panel (see Diagnostic Lights.)
Standby power light
AUX_PWR_LED on the system board
Hard-drive activity light
green light - When the computer is reading data from or writing data to the hard drive.
LAN indicator light
green light - Solid green indicates that a LAN (local area network) connection is established.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/adtshoot.htm#wp1056411
