Try holding down the power key for 30 seconds. You should see a white indicator light blink. If not then plug it into a charger that you know works. If your not using the original charger it may not be getting enough power. You may need to charge it for a couple of hours and then attempt to turn it on while on the charger by holding down the power button for atleast 30 secs or untill it turns on.
More than likely issue with phone or battery itself. Try another battery if you have one and see if it works. If you don't have an extra battery try to find someone who has a similar phone and try battery. If you call your service provider they will try to trouble shoot issue but more than likely will get you to send phone in through warranty if your still eligible. If not eligible for warranty and don't have insurance ask about upgrade options. Hope this helped.
unfortunately, you'll have to do a master reset on your phone. You'll loose all of your data. TO do this.. power off the phone. Then press the center select button (silver button on navigation pad) then power on the phone while keeping the sliver button pressed. You should get a Master reset prompt.. click Yes.
