Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
G
Garret Foute Posted on May 05, 2014
Ed25rfxfw01. I have an ED25RFXFW01 refrig whose ice maker 'trap door' won't shut all the way( about a half inch gap) when you stop dispensing the ice. Tried to take the clear shield loose to see if it was defective, but when replaced the door still wouldn't close all the way. Air coming out of freezer is causing ice build up around ice drop shoot.
Puddles Puddles
Level 1:
New Friend:
  • Contributor 13 Answers
  • Posted on May 05, 2014
Puddles Puddles
Contributor
Level 1:
New Friend:
Answers
13
Questions
0
Helped
5650
Points
23
Sadly, you will need to replace the entire 'flapper' assembly for this machine to fix this problem. This is the part in question. 8201649 for Whirlpool side by side. However, I would suggest if you can find the entire control panel assembly (which would be MUCH easier and have less chance to break things) to do that instead.
However, clearing the shoot wont do a thing for this issue at all.
Hope this helps ya ^_^
3helpful
Ed25rfxfw01. I have an ED25RFXFW01 refrig whose ice maker 'trp door' won't shut all the way( about a half inch gap) when you stop dispensing the ice. Tyied to take the clear shield loose to see if it was...
There is a good chance that the clear shield has come out of its mount and is jamming the mechanism. Check to see if this is thae case. It is a bit tricky to get it back in but you should see a tab on the back side of the shield and it clips into a slot on the actuator arm.
2helpful
Water freezes when going into ice maker model # ed25rfxfw01 whirlpool
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn't take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
RE: whirlpool refrigerator side by side ED25RFXFW01. I accidentally severed the water line inside the freezer door. How do I get to it? It appears that the shelves and insulation are glued to the door,...
The water line can be replaced by removing the dispenser cover and disconnecting the tubing and then pull the old line down from the bottom hinge area. once out, you can install your new line back up into the place it came out of. it goes through a channel inside the door. once back up in dispenser area..connect back to nozzle. the hose under freezer door needs to be connected as well...
2helpful
Ed25rfxfw01 whirlpool fridge water dispenser ...I have a slow drip from the dispenser hose. I assume I need a new water inlet valve. How do I access the inlet valve for replacing?
It should be on the right hand side in the back take off the compressor cover on the back should be 8 or so 1/4 screws nutdriver type and then two more hold on the water valve. If you have a RO system hooked up to refrig you may need to change the filters on the ro or just change the filter on the refrig. those two will also cause the water to drip thru the valve allowing it to drip on the front
2helpful
HI, I can help you. Is the water leaking from the freezer side?
Ice Maker Dispenser Motor Won't Stop Running
There is a plastic part in the dispenser that holds the micro switch that operates the auger motor when you push the paddle. If you're handy with hand tools, you can order the part and replace it yourself. The part is on the outside of the door.
No ice in the icemaker
there may be some problem with water inlet solenoid valve. the coil or valve could be faulty
Water filter leak Whirlpool ed25rfxfw01
I have an undersink filter from Whirlpool that is leaking also. I had an older one that also leaked and I replaced it. Worked fine for about six months then water all over under the sink. I believe it is leaking from the O-ring which seals the body and the cap. I think they have a lousy design and will look for another filter.
2answers
Maytag refrig (french door) water and ice on door stopped working at the same time.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
